horrible gas mileage...please help!!
Well, I have a 96gsr. All it has is a AEM CAI in terms of engine mods. I dont really drive all that aggressive for the most part. I shift between 3-4k, and probably only hit vtec once or twice a week. My smog numbers were crsytal clean (6, 6, 4)..something of that sort. About half of the average values. Well i got about 79 miles for half a tank in this past week. Im not throwing and check engine lights either
any ideas??? besides someone is stealing my gas, because i can see the drop each time i drive.
Maybe a tune up will help?
New plugs/wires and o2 sensor.
Than disconnect ground wire for a couple of minutes. Reconnect and start car and let idle for 10 minutes without touching gas.
fuel filter
then try valve adjustment, and check out the air and fuel system.
[Modified by Tweakmeister, 10:03 PM 10/5/2002]
check your timing.
When I was breaking my motor in after a rebuild, I purposely set the timing a little on the low side. 14 BTDC+/- I was getting about 200 miles per tank.
About 4 hundred miles ago, I advanced the timing to 17BTDC (factory is 16BTDC) and am now getting about 250 miles per tank.
I don't post on this site much because I rarely have any useful information. In response to SLOW CRX's post, however, visit http://www.ftc.gov/opa/2001/02/zmax1.htm. It seems that Z-Max does do something... as it's crapping-up your car.
Be VERY wary of Mechanic-In-A-Can stuff; the only thing I know to work is Restore.
[Modified by scn095, 10:19 PM 10/8/2002]
Be VERY wary of Mechanic-In-A-Can stuff; the only thing I know to work is Restore.[Modified by scn095, 10:19 PM 10/8/2002]
thats the thing, im not puffing any kind of smoke, and I dont see any gas dripping from the tailpipe. If it was the fuel filter, wouldnt I be bogging and what not? It was also replaced 1000 miles ago
Log4n
13
Feb 26, 2004 10:17 AM
