Victor X port-match inquiry!!!!!!!!!!!
Old Sep 4, 2011 | 09:28 AM
vtechjunkie's Avatar
Default Victor X port-match inquiry!!!!!!!!!!!
I have a 72mm BDL throttle body for my manifold, and I want to port-match them to one another. I don't want to get *** deep into this, only to find out that going this big will leave the wall thickness between the plentum and the IACV too thin. Is there anyone who knows if 72mm is too big for the Victor X?
Old Sep 4, 2011 | 05:17 PM
Default Re: Victor X port-match inquiry!!!!!!!!!!!
Anyone? Could this be the wrong section?
Old Sep 5, 2011 | 03:42 PM
I just need to know how big is gonna be too big. Should I just get a smaller tb?
Old Sep 7, 2011 | 04:00 PM
BEfab's Avatar
I have done a 70 with no problems. I would think you could do the 72, but I am not for sure.
Old Sep 7, 2011 | 04:55 PM
ej1serge's Avatar
why not email edelbrock? or get a gauge and measure
Old Sep 7, 2011 | 07:02 PM
Desir Performance's Avatar
Why don't you place the gasket on the tb flange and see where it falls, or wost case port it out as much as possible and relocate the IACV. What are you using to port it by the way?
Old Sep 8, 2011 | 02:00 PM
I was just wondering if there were any people that had done it without troubles with the iacv. I plan on having a machine shop bore it, so it comes out as nice as possible. And I don't want to sit down with a carbide bit for 3 hours to make it fit. I know there will be some meat left in the manifold, but with 20lbs. going through the tb, I don't want to have a failure while under boost, or on the track.
Old Sep 8, 2011 | 08:21 PM
ej1serge's Avatar
i would imagine 72 mm is ok because edelbrock says it works with a 75mm throttle body on their website
Old Sep 8, 2011 | 10:08 PM
jdmcivic2fast's Avatar
75mm should be the max bore on the victor x, more than that you are not going to have enough meat to seal.
I know this for a fact because I have one at 74mm and looks like it can go 1mm more, but no more than that.
Old Sep 10, 2011 | 01:00 PM
Awesome! That's what I was hoping to hear!
Old Sep 14, 2011 | 03:44 PM
Ricer no 7's Avatar
Don't have to take it to a machine shop its really easy
http://cms.skunk2.com/id/469/Skunk2-...Port-Matching/
Old Sep 16, 2011 | 09:23 AM
No air compressor, or I would.
Old Sep 16, 2011 | 10:56 AM
go buy a electric die grinder at Harbor freight, runs u about 30 bucks and get a carbide bit and cartridge rolls from local industrial shops, maybe 20 bucks for the bit and 5 bucks for the roll, you can do this all day long, and if you get good at it, u can start to port match peoples manifold and charge them for your time and labor.
Old Sep 20, 2011 | 12:45 AM
Hyper16-Johnny's Avatar
Wasn't Tony(T1) using an 80mm TB on his Victor X setup? Did he use an adapter for that big of a TB?
Old Sep 24, 2011 | 02:39 PM
Cost me $75 at my machine shop. Looks great! 72mm was no problem.
Old Oct 10, 2011 | 07:15 PM
MR.johnson's Avatar
i have a 76 on mine, just reweld the port on the outside and machine it flat.
polishedturd
Jan 11, 2008 10:11 AM
Muckman
Jul 13, 2007 03:11 PM
pearlteg
Dec 18, 2004 05:56 PM
IMSTOCK
Jul 27, 2004 08:55 AM
buck02
Feb 3, 2004 04:40 PM
