D15b pm3 with full ZC 97 head 10.5.1 cr
Old Sep 2, 2011 | 03:28 PM
Gt limited(jdm approved)'s Avatar
Default D15b pm3 with full ZC 97 head 10.5.1 cr
Present full specs
zc p2a higher lift and a regular d16y7 camshaft
pm3 pistons
zc 4-2-1 exhaust manifold
zc from 1997 db6 integra,block from carb civic ferio
b4 ZC 1600cc bad block
Change to full d15b pm3 block
By shaneoex at 2011-09-02
brackets
By shaneoex at 2011-08-15
Seeking more parts now i already have enough bolts
intake manifold
distributor
transmission
tuning
gas mileage should be great in a civic hatch i presently seeking
engine was black,dirty and ugly so diesel mixed with gasoline and a razor blade get it to its best looks
Old Sep 3, 2011 | 08:39 AM
rainmanef's Avatar
Default Re: D15b pm3 with full ZC 97 head 10.5.1 cr
what exactly is the purpose of this post? you want parts? if so this is the worng section
Old Sep 3, 2011 | 09:50 AM
its a non vtec build i couldnt bother post the rest of pics
motor soon meet body
Old Nov 26, 2011 | 04:49 AM
slywfbpsi's Avatar
why is this posted in the forced induction section?
Old Nov 26, 2011 | 04:50 AM
95civhb's Avatar
where's the FI?? You had me all excited for a D build...
Old Dec 16, 2011 | 10:07 AM
forced induction soon come either nos or turbo right now the project covered up until my starlet finishes
Old Dec 16, 2011 | 10:20 AM
kbouchard1092's Avatar
What happened to youre coolant housing on the head? get a little hungry? haha
Good luck with NOS or FI on a carb set-up haha...this should be on a fail blog
Old Dec 16, 2011 | 11:48 AM
nealnanoHX's Avatar
First off this is not a FI setup. Second IMO it is a lame build, a D15 with ZC SOHC VTEC head with a Y7 non Vtec cam and carb instead of fuel injection. Why??
Old Dec 16, 2011 | 02:11 PM
grumblemarc's Avatar
The Grumpiest
No it's not. You did this same nonsense in the Civic forum and all you did was post pics of parts. Never saw a build.
Old Jan 5, 2012 | 01:03 PM
intake manifold soon swap off i dont see the right one yet....
i wanted to start it on the ground with a carb to hear how it runs
and i took off the torque convertor because im waiting on the flywheel to come...
Tha person who said engine failed so what i least i tried Honda engine is not anything special to break its just a fun build even if its slow like a snail
Old Jan 5, 2012 | 02:01 PM
Never said the engine failed said this should be on a fail blog, and that it looks like someone took some bites of youre coolant outlet on the head....Although with a carb set-up and nos or turbo that will be soon to come. If its just a basic engine swap why post in FI? Its not anything special too break is right but you shouldnt be wasting youre time and money. Its really not worth the effort and time building a Carb anything when it comes to hondas....but whatever floats youre boat. good luck with it
Old Jan 6, 2012 | 03:42 AM
lol lol i never got the joke lol lol
the previous owner used water instead of coolant water kill blocks fast....rots the sleeves thats i why i change the short block to a d15b because d16/zc are hard to find in jamaica..
the manifold issue even if i install i fuel injector version i could posible start it on the ground anyways but it will come in due time i hate carbs myself...i heard of some hondas with one injector near the throttle body that setup would be easy bolt on...but i will change it anyways
Old Jan 6, 2012 | 05:54 AM
The one injector would be TBI ( Throttle body injection) I still would not use this with any kinda of boost. Maybe you could get away with a small shot like 35shot. I would still advise against it tho. You really need Fuel injection. I really wouldnt waste youre time. ALot of ppl run straight water most of the water, it would be in contact with aluminum which isnt going to rust. There isnt any oxygen in coolant passages to oxidize and create rust. If there was coolant in the cylinders and rusted them thats a different story. I would just do the engine swap, i wouldnt think about any type of FI. YOure just wasting youre time.
Old Jan 10, 2012 | 06:50 AM
thanks for the info i getting a straight pipe intake manifold the same one that came on d16y7 or jdm d15b base engines it should be fun i want to boost but dont know where to start maybe i should get the exhaust manifold with turbo first
Old Jan 10, 2012 | 08:02 AM
HiProfile's Avatar
OP, I would suggest you keep your build secret until you have a workable carb setup. Speaking of carbs, that intake manifold sucks no matter how you feed it fuel. The runners aren't wide enough for anything besides economy.
Wrong, oxygen is dissolved in the water no mater what you do. That combined with galvanic corrosion (steel water pump & tube, nipples, etc) creates a hotbed for orange and white crust to eat it up.
Old Jan 29, 2012 | 03:14 PM
Still dont find an intake manifold cheap yet i want the side draft d16y8 one not the popular downdraft d16y7
but i got this very cheap its kinda backway still civic rs tranny.... if its broke i will fix it the regular trouble spot is the starting off clutch because it doesnt have a torque convertor
By shaneoex at 2012-01-29
Old Feb 12, 2012 | 03:34 AM
slywfbpsi's Avatar
will someone lock this thread?
Old Apr 10, 2012 | 04:57 PM
oh alot of updates since.... engine is fine i even got a nice gearbox swap and clutch now ready to start. I got a super long intake manifold and using some toyota 5efhe injectors rather than the honda LEV ones. I even bought a starter and other missing brackets.Finally that carb intake take off and in the trash. Last thing i need is an ecu to run it. The motor looks cleaner now ready for boost
for injector rail banjo fittings, gas to clean up some stuff and start when the computer comes
By shaneoex at 2012-04-09
By shaneoex at 2012-03-10
Old Apr 11, 2012 | 09:41 AM
acquired intercooler... small wireloom presently working on it because it was spliced.i need ecu and map sensor next,but i need to put it back in the body/shell and work my way up i need new mounts too.
Old Apr 11, 2012 | 02:52 PM
got a high pressure fuel pump too
Old Apr 11, 2012 | 04:35 PM
rainmanef's Avatar
my yute. a wah yuh a try do? mi jus read all a wah yuh post and still nuh undastan nothing.
Old Apr 11, 2012 | 05:43 PM
Gunmetal_B20_Hatch's Avatar
looks pretty cool to me... interesting.
Old Apr 12, 2012 | 12:52 PM
not doing a thing boss
Old Apr 12, 2012 | 01:04 PM
Ok for those who never got or understand the project
First it came as a ZC from an integra and the block sleeves rot so i got a d15b pm3 block as replacement then add the ZC head
Now it look like this
By shaneoex at 2012-03-23
Old Sep 12, 2012 | 08:13 AM
Nitrous1024's Avatar
GT_Limited, did you get this engine started as yet?
