Autometer A/F Install Help Needed...
Old Oct 3, 2002 | 08:46 PM
Sirus's Avatar
Default Autometer A/F Install Help Needed...
OK. I need to know which power wire every one usually taps into. I have tapped into the white wire off the ecu, tapped into a ground wire, and ran the red power wire to a 12 volt acc wire going to the radio. My result is that I get one blink of a red bar then it goes blank. I used those double wire spice crimps to connect with. Could it be a bad connection? Wrong power wire? Or what? I've re-checked the connections and they all seem ok.
Old Oct 3, 2002 | 09:38 PM
speedymon's Avatar
Default Re: Autometer A/F Install Help Needed... (Blown99)
Ground-chassis
Power- to anything hot when the car is started
Old Oct 3, 2002 | 10:00 PM
Sirus's Avatar
Default Re: Autometer A/F Install Help Needed... (speedymon)
I tapped a wire within six inches from where it is grounded to the chassis. Would it make that much of a difference?
Old Oct 4, 2002 | 05:29 AM
fuguman's Avatar
New User
use the ground your radio uses.
i had funny outut when i had a bad power connection
Old Oct 5, 2002 | 09:04 PM
visi0n's Avatar
Default Re: Autometer A/F Install Help Needed... (fuguman)
behind your fuse box there is a black fuse spot that will provide 12volts...tap the power off that. oh yeah i mean the interior fuse box...
b16bri
Oct 8, 2021 03:20 AM
caliskier
Feb 2, 2008 10:44 AM
MrBryan
May 28, 2007 04:27 AM
technine
Audio / Security / Video
Apr 7, 2005 05:48 AM
OR-G
May 22, 2002 07:48 AM
