Need wire to bat. for new deck?
Old Apr 5, 2005 | 12:39 PM
technine's Avatar
Default Need wire to bat. for new deck?
I've been hearing on installing alpines that you should use a seperate power wire of a bigger gauge than stock (like 16-12g) run to directly to the battery, fused of course.
I'm installing an Alpine cde-9843 into my friends ride and I'm not sure if it needs it. Will my stock power wire be ok or am I missing out on not hooking it up to a seperate wire of bigger gauge?
Old Apr 5, 2005 | 12:53 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: Need wire to bat. for new deck? (technine)
do to the column for constant 12-volt wire. it's easier and mostly the same principle. if you'll pm me what car you have, I'll tell you what color and wear to tap the wire...
Old Apr 5, 2005 | 12:56 PM
technine's Avatar
Default Re: Need wire to bat. for new deck? (DAantagonist)
What about going to the fuse box and using an acc outlets? So you are saying that connecting the power with the stock power wire is not very effective??
Old Apr 5, 2005 | 01:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by technine &raquo;</TD></TR><TR><TD CLASS="quote">What about going to the fuse box and using an acc outlets? So you are saying that connecting the power with the stock power wire is not very effective??</TD></TR></TABLE>
I tend to stay away from the fuse box...and yes I am saying that. The stock 12v constant wire does not provide the current draw that radio needs to perform correctly. Honestly, I don't know what your car's radio circuit is capable of, but better safe than sorry right?
Old Apr 5, 2005 | 01:17 PM
technine's Avatar
I pulled the harness out and the power and ground wires are pretty fat, I'd say at least 16g wire. I just PM'd you. So I'll be hooking it to another source. Thanks DAatagonist.
Old Apr 5, 2005 | 01:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by technine &raquo;</TD></TR><TR><TD CLASS="quote">I pulled the harness out and the power and ground wires are pretty fat, I'd say at least 16g wire. I just PM'd you. So I'll be hooking it to another source. Thanks DAatagonist. </TD></TR></TABLE>
No problem sir...it's my job.
Old Apr 6, 2005 | 03:50 PM
technine's Avatar
Finished the install!! Now I know why Alpine is the best!! Like night and day difference. Thanks again Chris.
Old Apr 6, 2005 | 05:01 PM
EGPrelude's Avatar
im glad you finished the install but dont tag it from the fuse block ever. thats like the msot common place for radiated engine noise to enter your stereo
big no no from there
Old Apr 7, 2005 | 05:48 AM
Default Re: Need wire to bat. for new deck? (EGPrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGPrelude &raquo;</TD></TR><TR><TD CLASS="quote">
I think he got it from the column...
redsled00
Audio / Security / Video
Apr 10, 2009 10:17 PM
buzzsawstan
Jun 30, 2004 09:09 PM
cd5_2NR
Apr 20, 2003 09:47 PM
Sirus
Oct 5, 2002 09:04 PM
OR-G
May 22, 2002 07:48 AM
