flashing oil light in my R
Old Aug 31, 2011 | 03:33 AM
TypeRod's Avatar
Default flashing oil light in my R
so this morning as i was pulling away from house i had a flashing oil light. immediately turned around and switched cars to go to work. didnt get a chance to check oil level. past few days i have noticed a power loss when i down shift to pass someone. feels as if i hit the brakes and let off quickly. car is a 98 R, about 193K, stock motor. i dont notice any oil burning, has oil pan gasket replaced more than a year ago. possible oil pump going bad if the oil level is good? gonna check the level when i get home tonight. any suggestions to troubleshoot would be great! thanks!
Old Aug 31, 2011 | 04:48 AM
10sec4door's Avatar
Default Re: flashing oil light in my R
I had the same problem. It was my pump. Thank god I also had an oil pressure guage which showed the oil pressure very low. Put new pump on, problem was fixed.
Old Aug 31, 2011 | 05:03 AM
TypeRod's Avatar
so i guess its safe to assume if my oil level isnt low, then the pump is to blame? Thanks for ur feedback!
Old Aug 31, 2011 | 05:09 AM
oldintegrao's Avatar
I'm not 100% postive, but I do feel like that is one of the tail tell signs of oil pump failure. (This is the very very nice sign that tells you it may be failing. I would head any potential warning if you get my drift)
Old Aug 31, 2011 | 05:38 AM
TypeRod's Avatar
will do. Thanks again.
Old Aug 31, 2011 | 06:13 AM
01typerboi's Avatar
oil pump or your the oil strainer screen is clogged in the pan
95 integra's Avatar
It can also be a clogged/faulty oil filter....mostly problematic with fram filters.
Old Aug 31, 2011 | 06:26 AM
TypeRod's Avatar
Thanks typerboi and 95 for ur info! i will look into those as well. i cant even work right now, i just want to go home and help my baby! lol!
Old Sep 1, 2011 | 07:07 AM
10sec4door's Avatar
Yea, the oil strainer can def. get clogged. Same issue I had with mines, I forgot to mention that. It was caused by Oil filter coming apart (k&n). That caused my pump to go bad. So I put a new oil pickup and pump. Not that hard to do took me about 4 hours to take down oil pan remove pump and then put the new parts on.
Old Sep 1, 2011 | 09:48 AM
98R-1144's Avatar
Does anyone's oil light actually go off? I don't think I've ever seen mine go off, and it's been low a few times when I've checked to refill.
Old Sep 1, 2011 | 10:54 AM
95 integra's Avatar
It doesnt flash based on how much oil you have, it only flashes when your oil pressure goes low....which is usually when you have NO oil at all. If the pressure goes dead then you have about 5 seconds to turn the motor off before you trash bearings.
Old Sep 1, 2011 | 04:41 PM
PaulMc's Avatar
Painfully Stupid
I get that light all the time, I also burn a lot of oil. I need a rebuild.
Old Sep 6, 2011 | 01:21 PM
wunfstgsr's Avatar
Loved
Community Favorite
lol i would say so!
Old Sep 7, 2011 | 03:09 PM
TypeRod's Avatar
UPDATE: oil level was extremely low. dropped out the old stuff, and this time the filter was a beeyotch to take out, not sure why. but put new oil in and new filter and im hittin vtec all day long!!! LOL! I thought I could get away with stretching my oil changed to 7500miles from 5000. Nah, I dont think so!
Old Sep 7, 2011 | 08:48 PM
Quick99Si's Avatar
Aww **** yeah boyee break me off a piece of that more aggressive cam profile SON!!
Dec 28, 2008 05:00 PM
94ludeJDM
May 4, 2007 06:13 PM
B18Flip
Apr 17, 2004 05:15 PM
hondaracing1
13
Mar 31, 2004 04:32 AM
