95 del sol stock, failed emissions high co level
Old Aug 29, 2011 | 07:18 AM
krisfnbz's Avatar
Default 95 del sol stock, failed emissions high co level
Failed emissions for co's, everything else passed. My number was 285, and the limit is 175 in maryland. THe guy said the car is running rich. I recently just changed the motor, and stayed with the stock d15b7. all new basic tune up thing were done. NO CEL's. Im thinking fuel regulator, o2 sensor or mass airflow sensor? What do you guys think?
Old Aug 29, 2011 | 10:09 AM
new_game88's Avatar
10 Year Member
Default Re: 95 del sol stock, failed emissions high co level
o2
Old Sep 1, 2011 | 11:07 AM
krisfnbz's Avatar
Im sorry, I wrote the wrong thing. It is not failing due to a high CO level, its failing due to a high HC level. 285 is what it was at, limit is 175. I just got 355 miles on 10.8 gallons of gas, so thats about 33mpg, so its not running THAT rich, if at all....NO CELs
Motor is not burning OIL, and I'm about 80% sure its not burning coolant.
Old Sep 1, 2011 | 03:42 PM
krisfnbz's Avatar
new plugs, wires, cap, rotor, coil
the timing is correct, and the cat passed the test at the emissions station.
the car does have a small exhaust leak, as it is a bit loud.
just a bit more info.
Old Sep 2, 2011 | 01:38 PM
strategy400's Avatar
I have the same car/engine with automatic and get 37 mpg. Always pass smog.
Could the exhaust leak be letting outside air onto an O2 sensor? Is it pre-cat?
Are your plugs gapped to spec? Are they regular NGK ZFR5F-11?
Old Apr 1, 2012 | 10:31 AM
krisfnbz's Avatar
update: it was the cat converter, for anyone that ever reads this.
krisfnbz
21
Jan 22, 2012 08:28 AM
xx4GIVENxx
Aug 26, 2009 10:24 AM
240gtr
Nov 25, 2007 04:12 PM
B18Redline
10
Jan 4, 2006 04:43 PM
