Old Mar 25, 2015, 11:02 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Methods to stop coolant leak from water pump weep hole
Old Aug 28, 2011 | 08:50 PM
WingedMan's Avatar
Default Methods to stop coolant leak from water pump weep hole
94 Honda Accord LX 5 speed manual 4 cylinder non VTEC has air conditioning
I recently did an oil and filter change using hydrallic jack to raise car under cross beam under the engine
The next day car driven developed a small drip leak of antifreeze from weep hole of water pump that occurs after car warmed up, and drips for a few minutes after car parked and turned off.
The water pump makes no noticable noise.
Has happened subsequently in same manner every time I drive the car, leak so small not had to add any coolant
Wondering if I jarred the car and water pump when raising or lowering the car resulting in breaking the seal in the water pump, or loosening the bolts on the water pump. I am not wanting to replace the water pump, so maybe I could just take off the top part of the timing belt cover and tighten down the bolts on the water pump and hopefully stop this leak. Am I making sense??????
I am trying to find an inexpensive fix for this problem
Old Aug 28, 2011 | 09:40 PM
Nicefeet's Avatar
Default Re: Methods to stop coolant leak from water pump weep hole
If it's leaking from the weep hole the internal seal has gone bad
Old Aug 28, 2011 | 09:46 PM
GhostAccord's Avatar
There is no bolt that can be tightened to stop an internal seal leak in the water pump. Replacement is really the best option.
Old Aug 29, 2011 | 06:00 AM
Steve Z's Avatar
Exactly right. Time to change the pump out. While your at it, you might want to consider replacing the timing and balancer belts while you're in there. You can buy a complete set including both belts, tensioners, seals and water pump, gaskets etc.. for about $110. It's only going to get worse and spray coolant all over everything.
Old Aug 29, 2011 | 07:45 AM
h0p3l355dork's Avatar
110 dollars?! WHERE?! I've been checking all around for a timing belt kit and another HT member who works at a dealer quoted me 330 dollars for the whole kit. Granted my car is the 99 accord v6. Is it that big of a price difference?
Old Aug 29, 2011 | 08:25 AM
Rowdy Rod's Avatar
I bought mine at Advance auto parts for a 4 cyl for 110.00. STOP trying to buy parts at dealers. Try Napa or Orielys.
Old Aug 30, 2011 | 04:12 AM
Steve Z's Avatar
Here's the kit foryour car (1999 Accord). I assumed it was a EX V6 but never the less $330 is more than double as you can see. It's the same as for my F22B2, $105
http://www.fcpimport.com/products/ho...hondaaccordkit
Old Sep 27, 2011 | 12:43 PM
WingedMan's Avatar
I spoke to a long time Honda mechanic told me small leak from water pump weep hole is normal, not to worry about it since water pump not making any noise either.
Same info in Honda shop manual.
Therefore, since I do not drive this car far or often and my lack of money for this matter, I am delaying this repair.
Old Sep 27, 2011 | 02:36 PM
Steve Z's Avatar
Hmmmm, that just doesn't sound right to me. Whenever a water pump starts to weep its only going to get worse and eventually start spraying coolant all over the place and after that (and worse) overheat the motor. I'm sorry to be obtuse but it is NOT normal for your waterpump to leak coolant under any circumstances. The fact that the pump is not making noise is meaningless.
Old Sep 27, 2011 | 03:00 PM
Actually small amount of coolant from the weep hole, even when brand new, is normal. However, a stream of coolant leaving a puddle is not considered normal weeping. That is excessive and will require replacement. If the op is vigilant and keeps an eye on his coolant temps and level he should be OK for a while.
Hopefully he practices due diligence and puts a collection bucket under his car when ever he parks. Because we all know how F#@king annoying those people are who knowingly leak coolant all over the place.
Old Sep 27, 2011 | 03:10 PM
redbull-1's Avatar
Heehee....
Old Apr 7, 2016 | 06:50 PM
96Preluudddeee's Avatar
auto zone 120 I payed for my timing belt kit w tensioners water pump w gasket n timing belt
CAUTION: Dont bend ya valvez
Old Apr 8, 2016 | 04:51 PM
tamboo's Avatar
10 Year Member
dont sound right but maybe gates is just doing a cya due to recent rumored quality probs:
A small amount of coolant leaking from the weep hole is normal. Small drips are OK. Longer streams or continuous leaking may indicate a problem. OE manufacturers developed the weep chamber as a way to hide the small drips so pumps are not prematurely determined to be failing. Those drips will remain in the chamber and evaporate as the engine heats up.
More Information for GATES 41050
Old Mar 1, 2019 | 10:06 AM
John Wills's Avatar
advance $120
Old Jul 22, 2019 | 06:21 AM
strategy400's Avatar
Buy the water pump at least from the honda dealer. The aftermarket are crap. You don't want to re-do this. Use a proper torque wrench and torque the bolts to spec.
Old Jul 22, 2019 | 07:48 AM
GIZZ - EXV's Avatar
Loved
8 years later, I bet he got it fixed already.
Incase he didn't, or for anybody else shopping for cheap waterpump amazon or rockauto.com has $30 Aisin or Beck Arnley.
Old Apr 26, 2021 | 09:18 AM
hondaLUVlearn's Avatar
I recently took my 1990 Honda Accord to mechanic due to coolant leaking badly around timing belt area. which to me seemed to be the weep hole He did a pressure test and came back and said either head gasket or engine block crack. Would a would a bad water pump leaking coolant out of people causee my engine to fail pressure test?
Old Apr 26, 2021 | 05:03 PM
99stockcivic's Avatar
HondaLUVlearn,
Make a new thread if you can, this thread is a decade old. Don't re-use old threads like this if you can.
niceprelude
Feb 15, 2009 10:20 PM
Mr_Moos
Jun 24, 2007 10:04 PM
Mrob91GS
Mar 26, 2005 08:25 AM
tominos
Sep 10, 2004 08:38 PM
RedRyda
Jun 16, 2004 04:41 PM
