J32 Dry Sump conversion. Any thoughts?
Old Aug 28, 2011 | 04:59 PM
civichxtreme2's Avatar
Default J32 Dry Sump conversion. Any thoughts?
Now I have no plans on swapping a J series into anything anytime soon, but I did have a thought the other day while reading someones swap build. Since the main reason that the engines have to be mounted high is the oil pan clearance issue, why doesnt someone convert the motor to dry sump, I doubt it would be that difficult and it would probably make this swap much more desireable. Im aware of the added costs, but the benefits would be much more beneficial beyond just the oil pan issue. Any thoughts?
Old Aug 28, 2011 | 08:48 PM
king06's Avatar
Default re: J32 Dry Sump conversion. Any thoughts?
With enough money, anything is possible.
http://www.daileyengineering.com/dai...ering_home.htm
Old Aug 29, 2011 | 01:11 PM
I realize that it is possible, but is it a viable option. Anything is possible but would this be a significant thing to do to this swap to make it easier/better
Old May 11, 2019 | 07:40 AM
d962r's Avatar
the whole reason I joined this forum was for this little bit of information. Has anyone done this yet and if so could you point me in the right direction?
Old May 11, 2019 | 09:43 AM
Chance EG's Avatar
I've thought about this before as well. With a dry sump system the engine could be mounted lower in the bay while maintaining undercarriage clearance, and potentially remove the requirement for chopping the hell out of the hood.
Unfortunately, I am far from being able to afford a J swap with these bells and whistles.
Old May 13, 2019 | 06:35 AM
Dragged this one back from the dead didn't ya? As far as I know, nobody has done this, although I do believe that there are mounts that allow a better fit.
Old May 13, 2019 | 06:39 AM
d962r's Avatar
Nothing to do with mounts all though it is about getting the motor lower. This is for a mid engine sports racer with a Hewland sequential transmission. I need a dry sump system to lower the motor by3.5”.
Old May 13, 2019 | 06:41 AM
d962r's Avatar
Old May 14, 2019 | 05:21 AM
Ahh Gotcha, good luck. Someone may be able to custom build a system for you, as far as I know there is no off the shelf parts available.
skidmarkroyalty
Sep 27, 2008 09:14 PM
jdmcrx_echelon
Jul 19, 2006 07:12 PM
E.Honda
Dec 19, 2005 01:08 AM
Sliced Beard
Aug 13, 2004 05:28 AM
