External oil pump in the way.
Old Aug 28, 2011 | 04:52 PM
bigred850's Avatar
Default External oil pump in the way.
What kind of filter can fit over my T3 turbo with a 4" inlet, and also has part of the external oil pump chassis sitting in the middle of the inlet about 1/2 inch in? The external oil pump totally blocks every attempt I have made to put a filter on the turbo. Should I have the turbo system redesigned? Should I see if the external oil pump will be needed and try to get rid of it?
Does anybody have any ideas of a filter method I can use with some insurance I won't cause damage?
Old Aug 28, 2011 | 05:58 PM
TheShodan's Avatar
Moderator
Default Re: External oil pump in the way.
Engine? Chassis? Pictures? Size?
Old Aug 29, 2011 | 09:34 AM
bigred850's Avatar
The engine is a B18c1 on a CRX Si
https://docs.google.com/uc?id=0BxvO3...nload&hl=en_US
Ok, so as you can see from the photo above that the bolts to the external oil pump doesn't actually pretrude into the inlet at all it just sits there at the opening of the inlet. Any suggestions to what I can use for a filter with the pump still there in the same place? Thank you for advice.
Old Aug 29, 2011 | 09:52 AM
BLU CIVIC's Avatar
Track Advocate
due to your lack of space, you're probably better off with this
http://www.xenocron.com/xenocron-tur...ter-p-222.html
Old Aug 29, 2011 | 10:28 AM
rich7777's Avatar
Your better off making some sort of custom intake arm than using one of those things. Engines alone need a decent filter systerm.
Old Aug 29, 2011 | 10:35 AM
bigred850's Avatar
I see you point. I do have a custom oil system. It consist of a belt driven Proflo pump with external Moroso custom oil pan and an external pickup. I bought the car built and have no records of the build once so ever. Maybe if i could eleminate the external oil pump I can install the intake filter system. In most cases, is an external oil pump needed?
Old Sep 19, 2011 | 05:07 PM
bigred850's Avatar
Why would an external oil pump be required or suggested to have?
How long would it take to remove the external oil pump?
I really want the oil pump gone if I can do without it but I am not sure if it is required in my setup or not. As you can see the oil pump bolts sit RIGHT THERE at the inlet of my T3 turbo!! I am thinking the oil pump is going to be more trouble than it is worth. But I wanted to know what you guys have to say. I will be running low boost around 10psi or lower because this car is really my daily driver.
Old Sep 19, 2011 | 10:45 PM
W!d3b0dYr3X's Avatar
ummmm..... ya from the looks of that pic your only option is to run a screen like Blu Civic posted, or do away with the ecternal pump completely.
Old Sep 20, 2011 | 02:41 AM
bigred850's Avatar
I stumbled accross a great thread on honda-tech that explain you can use a part of a t-shirt or a sock and a clamp as a good filter. How hot do T3 turbo inlets get? I should be ok with the shirt idea right as far as not catching the cotton on fire?
Old Sep 20, 2011 | 03:11 PM
I wouldn recommend doing that. The turbo could potentially suck the shirt into the compressor wheel and wreak havoc.
TomCat39
Oct 1, 2018 09:36 AM
BlUAc
Aug 6, 2007 09:04 PM
Steak84SS
Apr 13, 2004 07:36 AM
JalopySiR
Dec 22, 2003 07:21 PM
