noob question...
what is the best intake manifold to run for my all motor set up?
B20v setup
gsr head stage 5 port
b20b block 84.5 mm bore
weisco 13:1 pistons
stock rods
gsr crank
acl race bearings
skunk2 internals
skunk2 pro 3 cams
competition stage 5 clutch and ultra light flywheel
aem fuel rail and fpr
RC 750injectors
might be forgetting a few other things but plan on using a 70tb btw
B20v setup
weisco 13:1 pistons
stock rods
gsr crank
acl race bearings
skunk2 internals
skunk2 pro 3 cams
RC 750injectors
The stock rods are weak. You might want to replace them. Here's a link to one of my friends b20vtec builds that he wanted advice on. https://honda-tech.com/forums/showth...ec+build+plans http://www.azht.net/forum/showthread.php?t=154076 The 70mm tb is pretty big unless your going to boost it down the road. Also those cams are pretty aggressive if this will be your DD.
The one that provides you optimal power and anyone tells you different is just guessing until you do some testing. Rethink or rephrase your question for suggested recommendations to test with.
With the compression and displacement you have the Performer X would suit that setup well. Anything smaller I feel would be causing restriction. Get that TB port-matched and call it a day.
performer x is actually better on a 1.8 motor skunk2 is nice i personally like the aebs thats what im running on my b20vtec with gsr head i like the design of the aebs for the p72 gsr head better then most other intakemanifolds and they prove to make a bit more power then most others. plus the cost
to be honest the amount of money already put into the motor, if you had the $ and tuning ability itbs would make a world of diffrence, also are you looking for low to mid range or high end? the edlebrock victorx is great but its power range is set for higher rpms, not that it dosnt perform well mid and low just others can do better for torque but not knockin the victor x its a beast top end wise
Wrong stock rods are not fine with forged pistons. They won't even work unless he has the machine shop alter the clips. And even then its a waste of money. If you were going the rs itr piston route I would say go ahead but imo I would not cheap out on a crucail part of your motor.
as far as the intake manifold goes ive heard good things about the ported itr manifold on 2.0
just get the rods shot peened w arp bolts... and i also have seen great results w a ported and polished itr manifold... thoughs intake manifolds were ment for racing so they flow great to begin w... just a little port and polish and u have urself an IM thats just as good as any aftermarket...
