E-brake problem 97 civic
Old Aug 28, 2011 | 11:52 AM
EFREN's Avatar
Default E-brake problem 97 civic
Ok so i am currently putting together my little project.. Its 97 dx sedan.. So i currently installed my rear disk brakes which came off an em1 so i know i have the correct cables. But when i engage the lever the left side is engaging but i can still spin the the hub. I already have tried adjusting. And nothing changed.
Also this little piece is pulling crooked left side being higher..
Old Aug 28, 2011 | 11:57 AM
Former User's Avatar
Default Re: E-brake problem 97 civic
The star adjuster may be adjusted differently on one side than the other, or the pads/drums are worn differently.
Old Aug 28, 2011 | 12:03 PM
1996CivicEXEJ8's Avatar
^^^x2
EFREN's Avatar
That star adjuster would be on the caliper?.. I just put on brand new pads.
Old Aug 28, 2011 | 12:13 PM
Never mind about the star adjuster. I forgot you had rear disc brakes.
These may help:
Old Aug 28, 2011 | 12:34 PM
EFREN's Avatar
I just took it that far up and did nothing for it..
Old Aug 28, 2011 | 12:40 PM
EFREN's Avatar
Mmmmm i did a brake line tuck.. But been having problems bleeding the system.. I cant start the engine..(harness is not ready) to be able to do the self adjusting thing. Could that be a possibility?
Old Aug 28, 2011 | 08:23 PM
EFREN's Avatar
Bump... Anymore suggestions?
Old Aug 28, 2011 | 08:26 PM
Get the engine running first so that you can do the self adjust. Then go from there.
s.son
Jun 30, 2010 05:09 PM
Syndacate
17
May 11, 2010 08:20 PM
B Fish
Suspension & Brakes
Mar 1, 2010 04:19 PM
