code 16 1991 dx hatch
Old Oct 3, 2002 | 06:12 PM
wannab20hatch's Avatar
Default code 16 1991 dx hatch
i have a 91 dx hatch automatic and my car wont start interior is removed already and my ecu is flashing codes 16 whats goin on here? Thanx for all the help. ooh and how do i fix this problem
Old Oct 3, 2002 | 07:56 PM
Default Re: code 16 1991 dx hatch (wannab20hatch)
Anyone?
Old Oct 3, 2002 | 08:09 PM
the DR.'s Avatar
code 16 is about an injector, have you done anything recently to your car? do you have access to (an)other dx injector(s)?
Old Oct 3, 2002 | 08:45 PM
Default Re: code 16 1991 dx hatch (CIVICtypeS)
I pulled out all of my a/c crap but nothin else. Im about to buy another dx motor so yes i do have access to another injector.
Old Oct 4, 2002 | 08:36 AM
someone has to know
Old Oct 4, 2002 | 11:00 AM
Perfectionist's Avatar
Well, since you asked... code 16 is an interruption in the electrical circuit for the injectors. The path is fuse to ignition switch to main relay to injector resistors (if you have them) to injector coils to ECU. Since you worked on the interior, I would suggest you check for power to the main relay and then look for 12 volts at the injectors. (Ignition ON but engine not running) It doesn't matter which injector you measure at. They all get power. The ECU selectively completes the circuit to ground as required.
SupraRXZ
Apr 6, 2006 09:48 AM
4ghatch
Jan 16, 2003 02:33 PM
4ghatch
Jan 11, 2003 06:57 PM
11secdx
Oct 22, 2002 04:51 PM
