Q31 FRIED H22 TURBO
I need help my car fried the q31 but no cel codes but the problem the vtec not working.. please help i put p28 chipped and fried i put p06 chipped and fried too
q31 being burnt is usually from some one mixing up the evap purge solenoid and intake air temperature plugs in the engine bay.
Your intake air temperature sensor is likely damaged.
q31 isn't a needed component in the ecu if you eliminate evap purge solenoids, you can simply remove it.
creepy116
Dec 19, 2007 10:33 PM
AllMotor12s
Oct 21, 2005 09:17 PM
BigChris
Dec 13, 2002 06:51 PM
