recommended tires for 370whp gsr??
Old Aug 26, 2011 | 10:13 PM
Excusetoboost's Avatar
Default recommended tires for 370whp gsr??
i have nitto neogens on the car and it drags second gear just spinning, depends on how i shift it may spin 3rd, i tire of loosing races because i cant hook, what tires would you guys recommend?
Old Aug 26, 2011 | 10:18 PM
Default Re: recommended tires for 370whp gsr??
which tires??
Old Aug 26, 2011 | 10:46 PM
omiehomie's Avatar
dunlop direzza star specs , hankook RS3's, Kumho XS, or hell i think its a nitto Nt05 i think
if its an integra try a 215 or 225 in the front for grip and maybe a good suspension + alignment if you already dont have those done.
do you have hondata? have you looked into boost by gear? that is what i have on my gsr and it gives pretty civil grip.
just my two cents.
Old Aug 26, 2011 | 10:52 PM
dk=gsr's Avatar
the nitto Nt01's are pretty good too.
Old Aug 26, 2011 | 11:05 PM
Jimmynitro's Avatar
Mickey Thompson drag radial
Old Aug 27, 2011 | 04:22 AM
ook, i heard of the nt 01s , i might try those... and no the car is still stock height..i knoo i need suspension lol
Old Aug 27, 2011 | 04:24 AM
are the Mickey Thompson drag radial better than the nitto nt 101?
Old Aug 27, 2011 | 06:32 AM
CDecker0218's Avatar
MT 205/50/15
Old Aug 27, 2011 | 06:44 AM
Root of all Evil's Avatar
nt01 is a r comp designed for road racing not drag. I can hook 450whp on 205 azenis using right foot traction control.
Old Aug 27, 2011 | 07:37 AM
Jimmynitro's Avatar
For drag racing yes the mickey Thompson are one of the best choices
Old Aug 27, 2011 | 08:38 AM
4cylfiend's Avatar
If you want to hook the power on the street I would go with a 225-50-15 (if you run 15's) mickey thompson et steeet. Radial. When you get into the 500whp mark you will need to start lookin into a dot bias ply.
Old Aug 27, 2011 | 08:51 AM
Gunmetal_B20_Hatch's Avatar
225-50-15 MT ET Street and a 15x8 wheel if you can fit it.
Old Aug 27, 2011 | 09:23 AM
th3pwn3r's Avatar
Icon3 Re: recommended tires for 370whp gsr??
No way man. You gotta use boost by gear, you're supposed to mash the right pedal all the way through the floor!
Old Aug 28, 2011 | 08:49 AM
Thanks guys, I will try the MT drag radials.
Old Aug 28, 2011 | 11:29 AM
pcguy760's Avatar
MT Drag radials for 370 whp???? I am using Falken Azenis RT-615's up front and barely ever have traction issues, but I do have traction bars and adjustable shocks Also my big *** turbo helps me get traction in 1st and 2nd haha
Old Aug 28, 2011 | 11:42 AM
1320em1's Avatar
with 400whp mt 225 50 15 ftw
Old Aug 28, 2011 | 01:50 PM
Turbo-LS's Avatar
BOOST BY GEAR !!! No street tire is going to hold that kind of power in second gear unless you run a drag radial oversized that equals out to be about a 26" tire.
Im making over 400whp in my gsrand im running Falken ZE912 performance all season tires and they hook in every gear.
Old Aug 28, 2011 | 07:02 PM
blackeg's Avatar
Yea boost by gear is an essential, though sometimes a car will make enough power right off the gate that really warrants a bigger tire. I make 390 whp on my lowest boost and my 225/50/15 bfg radials do a pretty good job of it.also from experience I found that slightly reducing the preload on the rear suspension helps keep some traction. See if you can pick up some rt615s or the mt radials in a 225/50/15 you should be ok
Old Aug 28, 2011 | 08:34 PM
pcguy760's Avatar
Boost by Gear x2
Old Aug 29, 2011 | 05:04 AM
DelSolMarine's Avatar
Toyo R888 or Toyo RA1
Old Aug 29, 2011 | 02:58 PM
MR.johnson's Avatar
i had a 225 50 mt now going with racemasters
oscarmayer
Mar 22, 2007 05:04 AM
TrizzyDizzy
43
Feb 7, 2005 04:59 PM
xstalkrx
Dec 31, 2003 03:01 PM
KooK
Sep 26, 2003 09:47 PM
el arbi
Aug 23, 2003 08:59 AM
