k20a2 rpms limited to 2k help
Old Aug 26, 2011 | 04:14 PM
95eggsr02em2k20's Avatar
Default k20a2 rpms limited to 2k help
hello i have a 02 em2 with a k20a2 swap. Today i was on the way home from work, when i got on the highway i pulled thru the gears and in 3rd at about 6700 it fell on its face. I pulled over and checked gauges, i then atempted to pull away and it now it will not acc past 2k rpms. I got no cel from this and i drove about 10 miles after the problem occured. i have hondata that i realy dont much about but after i limped it home i pluged in the laptop and i dont c anything but when i do go over 2k the inj voltage drops. i checked the oil and looked for any wires astray but nothing. If anybody can help it would b nice. thanks.
Old Aug 27, 2011 | 04:17 AM
Default Re: k20a2 rpms limited to 2k help
Any thing I could use any help
Old Aug 27, 2011 | 12:02 PM
has anybody heard of this
Old Aug 27, 2011 | 02:59 PM
apexi_rsx's Avatar
why not save the map you have and try using another map? see how another base map may work.
Old Aug 28, 2011 | 04:43 AM
iwill try that but i already refreshed the map i was using and it was no diff
Old Aug 28, 2011 | 03:38 PM
it made no diff i think kpro is fing me
Old Aug 28, 2011 | 03:39 PM
i need to find a ecm and key to try
Old Aug 29, 2011 | 11:39 AM
anybody got anything im lost
Old Aug 29, 2011 | 01:16 PM
Earthworm Jim's Avatar
why don't you try putting the stock ECU back in, letting the car sit, while on for five minutes and road testing it.
Old Aug 29, 2011 | 04:27 PM
i dont have the stock ecm and it is a swap so the key wouldnt match anyway but today i saw the tps it cracked, the plug conecter it in but that side is loose. i havent had any issues with k series but the 1 in my gsr went bad, when it did i still had full funtion exept at wot. does anybody have exp. with broke k series tps. is the funtion the same
Old Aug 30, 2011 | 08:09 PM
andrewkeisler's Avatar
possibly vtec solinoid or something is restriciting rpm..
Old Aug 30, 2011 | 08:14 PM
Fliptard's Avatar
If ur tps isn't hooked up or broke, your car will run fine, but wo't go passed a certain RPM, it's like a rev limiter. If your tps was broke or the plug was, swap it out, calabrate it and try that.
Old Sep 7, 2011 | 04:46 AM
i have been trying to find a used 1 but dont have any luck am i right that it is only for the k series tb
youngboiCD7
Engine Management and Tuning
Apr 12, 2018 06:13 AM
dbb95ex
Mar 7, 2014 02:34 PM
1baddcivicsi
Jun 14, 2013 10:17 AM
