Car Overheating (D16z6)
Old Aug 26, 2011 | 09:33 AM
preetyboi06's Avatar
Default Car Overheating (D16z6)
Whats good people.... I am having some trouble with my car overheating. I have a 94 civic si hatchback with a D16z6 motor in it and the other day it just started over heating and wont stop. I have changed all the hoses and added new coolant and still it will overheat after about 30min of driving or just sitting at idle. The fan for the radiator works and there are no leaks. Can someon please help me located why this is still happening.
Thanks for you help.
Old Aug 26, 2011 | 09:54 AM
sk8kingda3rd's Avatar
Default Re: Car Overheating (D16z6)
Have you replaced the thermostat? How'd your coolant look when you changed it?
Old Aug 26, 2011 | 10:18 AM
No I have not replaced the thermostat but if that was bad would the temp guage in the car work? Also its was the normal neon green color. I am not 100% sure how it looked honestly. But thanks for replying and helping out
Old Aug 26, 2011 | 10:19 AM
Also I should add when it first started overheating you could hear like air being released from the back of the block almost like something had a leak but like I stated i changed all the hoses so I have no idea where that noise was coming from...
Old Aug 26, 2011 | 10:29 AM
Well no idea on the noise, my only guess would be steam being released from the cooling system but that would be extremely visible and obvious. As far as the thermostat, your gauge would absolutely work still. The sensor for the gauge is the single wire one below your distributor and is completely separate from the thermostat. Replace your thermostat and see if that helps, its cheap and requires two bolts to be removed to replace.
Old Aug 26, 2011 | 10:33 AM
grumblemarc's Avatar
The Grumpiest
Thermostats are too cheap NOT to try and swap it out. At the very least you can test the one you have to make sure it is working.
Old Aug 26, 2011 | 10:46 AM
ej1b18c1's Avatar
Use a OEM Honda thermostat!!! Save yourself time/money in the future. Aftermarket stats are garbage but will work short-term ok. You can always just remove it if in a bind and need a quick fix till you get it replaced with quality IMO. Do NOT wait to solve this problem or drive on it overheating otherwise you will cause other damage like head gasket etc..
Old Aug 26, 2011 | 10:48 AM
Gotta love how a nine dollar problem will turn into a thousand dollar problem when not taken care of
Old Aug 26, 2011 | 11:36 AM
Thanks you all for your replies I will get a new OEM Thermostat today.... Now a noo question how the hell do you change it? Where is it located?
Old Aug 26, 2011 | 11:44 AM
Well you said you replaced your hoses so....it is located in the thermostat housing, which is the spot where you attached your lower radiator hose. Just trace your lower radiator hose to where it connects to your block, there should be two bolts where it connects, you pull them out, pull out your old thermostat and put the new O-ring on your new thermostat and put it in and retighten the bolts.
<img src=>
Old Aug 26, 2011 | 11:48 AM
kyle09's Avatar
when you start the car where does the temp gage? does it start at the bottom or like half way up. and how fast does the gage go up?
Old Aug 26, 2011 | 11:58 AM
When I start it, it starts off cool (bottom) and after about 20-30min then its get HOT!!!(top) and it goes right up to HOT!
Old Aug 26, 2011 | 11:59 AM
<img src=>
Thanks for all you help meng....
Old Aug 26, 2011 | 01:38 PM
strategy400's Avatar
A good idea to repace the thermostat as preventive maintenance. Make sure to install the gasket/jiggle valve correctly (facing up).
You said there's noise near the intake. Check for an intake leak like a cracked manifold or failed intake gasket. That could cause overheating as well.
Old Aug 26, 2011 | 03:05 PM
apexi_rsx's Avatar
i know when my car over heated once all i could hear and see was coolant was spraying sum where and my hose split causing ti to over heat. check ur hoses if ur hearing a hiss for cracks or pin holes in ur hose as it pressurizes it will build pressure and hiss out the split or pin hole..
MattsLegit
10
May 12, 2016 05:52 PM
k24es1
Apr 23, 2014 07:50 PM
Panda Eg6
Jul 17, 2007 04:09 PM
Basically
12
Apr 7, 2005 04:23 PM
verseone
May 24, 2002 01:12 PM
