crank pulley removal.. dumb question
Old Aug 25, 2011 | 06:13 PM
EJ8CIVIC's Avatar
Default crank pulley removal.. dumb question
ok i got this d16z6 that has a aftermarket crank pulley.. and i dont like it so im goin to swap back to stock
my question is
can i unbolt the aftermark one and put the stock back on w/o redoin the timing?
i bet i know the answere is no.. but i just want to clearfly before do it
Old Aug 25, 2011 | 06:21 PM
Frozen E's Avatar
H-T White Ops
Default Re: crank pulley removal.. dumb question
What do you mean by "redoing"? If you're talking about having to pull the valve cover to reset the cam to TDC after it moves because that crank bolt is a bitch to get off, then no, you probably won't be able to get away with that.
Well, unless you have the tool that locks your flywheel in place and keeps your cam from moving. That's about the only way I see you being able to change a crank pulley without the cam moving, and having to worry about timing being off.
If you don't have the flywheel tool, I'd say go get a new valve cover gasket set and do it right, because the chance that your cam will move is pretty damn high. Not worth risking valve/piston damage over.
Old Aug 25, 2011 | 06:22 PM
98civdx's Avatar
Master Detailer
If you don't touch the belt, and you insure you don't more anything you shouldn't have to worry about the timing. At least I couldn't see why you would need to.
But, I would deffinetly check the timing, (little tick mark) and insure it's still at tdc before you start the car. Just to be safe.
Old Aug 25, 2011 | 06:25 PM
Fliptard's Avatar
Or just undo the bolt via impact, in 5th gear while car on ground, or jam something into the flywheel, tap pully with w.e, pull off, place new on and torque to specs.
EJ8CIVIC's Avatar
i can make a diy tool that locks the flywheel in place.. i did a google search and got a couple idea
this the idea im goin to do
snag this pic from d-series.org
Old Aug 25, 2011 | 06:27 PM
98civdx's Avatar
Master Detailer
Are you not able to use that crank pulley tool?
Old Aug 25, 2011 | 06:33 PM
Frozen E's Avatar
H-T White Ops
Unless your tranny is off your engine, you won't be able to access the flywheel like that.
Old Aug 25, 2011 | 06:40 PM
EJ8CIVIC's Avatar
i got the crank pulley tool
Old Aug 25, 2011 | 06:41 PM
EJ8CIVIC's Avatar
ooh yea the tranny is already off the motor
foolsforever
11
Aug 9, 2018 05:08 PM
a.ramirez82
Apr 22, 2011 10:44 AM
jyracer
Jan 29, 2009 09:29 PM
MenaceL.A.671
Sep 13, 2005 07:16 AM
dpo95si
Aug 17, 2002 08:11 AM
