90 accord mt question
alright long story short had a buddy over helping me work on the car and while i was removing the bearing/hubs for a roh conversion he was supposed to be draining the mtf. but im pretty sure he removed the wrong thing to drain the fluid. there are two plugs on the passenger side of the tranny that are visible through the wheel well. both have a 1/2" drive hole in them. he used a half inch drive and removed the bottom plug and a very small amount of black fluid came out. i immediately replaced the plug when he said the tranny had no fluid in it.
been scouring the internet to try and figure out what he did and i cant seem to find any info. what the hell did he just drain and how do i fix this.
That would be the transmission oil. If it wasn't a plug in the block and it was in the M/T housing, it's transmission oil that came out. The larger Upper bolt is the fill hole and the lower 1/2" is the drain plug
so is that a different fluid then the mtf fluid. i see the 19 or 17mm filler bolt and the 3/8" drain plug closer to the driveaxle where the mtf is drained and filled.
what im unsure of is if the larger 1/2" lower plug to the right and the 3/8" plug right above it is also mtf or is it some kind of gear oil? my transmission ran great before i started taking things apart just wanna make sure it stays that way
ok guys my question was not too hard
my mt has 4 different plugs in it. two closer to the bumper and two closer to the firewall.
firewall plugs:
3/8" on bottom
17mm on top
bumper plugs:
3/8" in top
1/2" on bottom
what are the bumper plugs for?
firewall plugs:
3/8" on bottom
17mm on top
bumper plugs:
3/8" in top
1/2" on bottom
ok so your saying both 2x drain plugs and 2x fiill flugs contain the same honda mtf?
if your looking in the passenger wheel well. to the right of the knuckle assembly there is a 1/2" plug and then a little bit above that there is a 3/8" plug.
yessir this i am well aware of. my problem s what are the plugs that are to the right of the driveshaft. my buddy loosened the lower one and let some fluid out. is there some other type of gear fluid in these transmissions or was that just mt fluid also
Oh yeah..sorry forgot what the initial issue was. Only fluid reservoir to be found in a M/T would contain ether 10w30(40) or MTF. There are no other fluid reservoirs in the M/T.
I'd still like to see a pic of the plug your buddy loosened, if possible.
alright im trying to get someone over here to take a picture
northkai3
26
Sep 29, 2013 11:53 AM
The Internet Tough Guy
Nov 1, 2003 12:37 PM
