What motor oil best for high milage engines?
Old Aug 24, 2011 | 11:52 AM
Rowdy Rod's Avatar
Default What motor oil best for high milage engines?
5w-30 is what Honda recommends for my 97 Accord, but would 10w-40, or 20w50 be ok? I have 200,000 miles now and live in a fairly warm climate.
Old Aug 24, 2011 | 11:57 AM
1991civiclx13's Avatar
Default Re: What motor oil best for high milage engines?
keep using 5w-30... why do you want to change? what will this cure?
Old Aug 24, 2011 | 11:59 AM
NZDM's Avatar
10 Year Member
Generally on higher milage hondas, if they are a wee bit smokey and tired, it would be a good idea to run a slightly thicker oil than factory reccomended.
A 15w 40 or 20w 40 should do the job.
Old Aug 24, 2011 | 12:29 PM
TheMuffinMan's Avatar
He knows where you live!
If you aren't burning or losing oil then just stick with what you have been (factory recommended)
Old Aug 24, 2011 | 01:44 PM
hondamark35's Avatar
use the recommended weight.
think about it... if a thicker oil won't seep out and leak as easily as a thinner oil, it also will have more trouble flowing into all of the lube points of the engine. not awesome.
on a high mileage engine it's more important to keep the fill level in check.
<rant> if it's not worth rebuilding it's not worth different (or fancy..) oils and additives. fill it with the cheapest 5w-30 you can find and keep plenty on hand so you never run low.
Old Aug 24, 2011 | 03:00 PM
Rowdy Rod's Avatar
My engine uses oil but never smokes. 200,000 miles. I figured going to thicker viscosity will help with oil consumption.
EG-SIXV-TEC
27
May 3, 2010 09:27 AM
globy123
12
Oct 18, 2009 03:01 PM
cautrell05
Jul 9, 2008 10:17 AM
99 HXagon
21
Jul 26, 2002 06:28 AM
GruvyTune
Jul 24, 2002 09:58 AM
