PCV system doesn't seem to be working on new B20Vtec....HELP!!!!!!!!!!!
Old Oct 3, 2002 | 04:22 PM
InfamousRS's Avatar
Default PCV system doesn't seem to be working on new B20Vtec....HELP!!!!!!!!!!!
Okay, I have the PCV valve hooked up inline between the valve cover and intake manifold. Its only temporary till I buy a oil catch can. Well anyways I can tell ALOT of pressure is building up in the crank case cause its blowing the dipstick out every few miles...I thought it could have been that the PCV valve was bad, so I replaced it with a new one and its still doing it. Does anyone know how I could fix this?
Old Oct 3, 2002 | 04:35 PM
InfamousRS's Avatar
Default Re: PCV system doesn't seem to be working on new B20Vtec....HELP!!!!!!!!!!! (InfamousRS)
Does all of the crank case pressure exit out of the valve cover if the PCv is working right? Should I just rought a hose off of the valve cover with a small filter on it for now? I have to drive home tonight (150 miles) so I need to do somthing.....
Old Oct 3, 2002 | 05:09 PM
S-Hall's Avatar
Default Re: Pcv
Man the Pcv system suchs air into the valve cover. you may have the PCV valve backwards. check that. if no that check these links and see if shead any light. HTH
http://forums.hybridgarage.com/showf...w=&sb=&o=&vc=1
this one is good
Old Oct 3, 2002 | 05:33 PM
mannyman's Avatar
El Veterano de Sur Califas
thats not enough to releive the pressure. You need to buy the endyn breather kit.
erikiksaz1
Engine Management and Tuning
Sep 25, 2011 09:37 PM
Black R
Jan 25, 2010 07:18 PM
hondadriver
Mar 14, 2006 08:03 AM
Ri5e
Aug 11, 2002 03:28 PM
GruvyTune
Oct 22, 2001 01:29 PM
