FS: 11.1" 4x100 Type-R upgrade!
4x100 Integra Type-R front brakes upgrade for Civic EXs and Integras - SOLD
This is a set of the rare 4x100 front brakes for a Civic and Integra. This is a pair of ITR front calipers with the 23T brackets machined to fit the 4-lug knuckles. This also comes with a new pair of Prelude VTEC rotors. This was made by a former member of h-t.
This brake upgrade is a behemoth of an upgrade over stock, using the big *** Type-R calipers with the 57mm pistons. The brackets were precision milled to fit. The rotors were redrilled with a milling machine to 4x100. This bolts onto any 90-01 Integra (exc 96 ITRs), and any 88-05 Civic EX, 99-00 Civic Si. This can fit any other 88-00 Civic if you get Integra or Civic EX knuckles, as their knuckles are different with regard to the caliper mounting point.
You will want either a 15/16" or 1" master cylinder if you have a Civic.
I have drilled/slotted rotors too, just ask.
also as a selling point -
any non-EX trim civic (such as CX, DX, etc.) can use the calipers and brackets with GSR rotors for a direct bolt on upgrade as well - giving you 10.2 inch rotors with ITR calipers...
have these on my track car, and yes the do stop quite well...
hondapwr
Sep 13, 2006 03:36 AM
s1ngle
Sep 4, 2005 12:27 PM
