Civic cuts out on highway
Old Aug 23, 2011 | 10:23 AM
Jasmine1's Avatar
Default Civic cuts out on highway
My civic has a problem that’s getting worse. Randomly on the highway the car will cut out for about 10 seconds or so then regain power. The engine is still running, but you can punch the accelerator and nothing. Car drives perfect before and after this happens. It’s started out very intermittent happening one time every few days, now last night on the highway it cut out every ¼ mile or so. I got off the highway and cruised on back roads and it didn’t happen.
89 civic, Swapped d16z6
No check engine light
Newer plugs, wires, cap, rotor.
Newer walbro pump and aem regulator
Good compression,
Timing to spec
Rotor is on tight
I swapped the coil and igniter from a friends car and that didn’t help.
Old Aug 23, 2011 | 10:54 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Civic cuts out on highway
You might want to have this moved here.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/
Old Aug 23, 2011 | 10:59 AM
kaiba's Avatar
At what speed does it start cutting out.
Old Aug 23, 2011 | 11:27 AM
Jasmine1's Avatar
Posted it here because it has a 94 motor
It happens cruising at 55, 60, 65 mph, never while accelerating. It will suddenly loose power. It doesn't bog or buck, just loses power (motor still running) for 3-10 seconds and then starts to act normal.
Old Aug 23, 2011 | 11:39 AM
HondaPartsHero's Avatar
Technical Hero
So when you press the throttle nothing happens while cruising? Just wondering because you say "cuts out" but just trying to confirm engine is running, throttle is pressed, no acceleration?
Old Aug 23, 2011 | 12:04 PM
Jasmine1's Avatar
Yes. The motor continues to run. It instantly loses all power for 3-10 seconds, then instantly acts normal again. Only happens when cruising on the highway.
Old Aug 23, 2011 | 12:16 PM
SlickC95's Avatar
here is my 2 cents....my car 89 hatch was doing the same it had the stock motor and the first day i picked it up at a used car lot it was doing the same on the high way so i took it back to them and they said they changed out the fuel pump strainer and put a new main relay in....now the problem is fixed
Old Aug 23, 2011 | 12:19 PM
Former User's Avatar
Is the car running an OBD0 or OBD1 ECU?
Do you lose ignition switch power? If so, test the switch. If not, have the igniter unit tested.
Old Aug 23, 2011 | 12:36 PM
Jasmine1's Avatar
Thank you for your input.
OBD1
IDK, is it possible to lose power to the ignition switch while the motor is running?
I swapped in a known good coil and igniter and that didn't help
Old Aug 23, 2011 | 12:45 PM
Sure. Do you lose any electrical power when the engine loses power?
Have you inspected the plugs, wires, cap, and rotor?
Have you resoldered the main relay?
How do you know the engine is still running when you lose engine power?
Does the CEL work?
Old Aug 23, 2011 | 12:52 PM
Jasmine1's Avatar
Nope, radio, gauges lights all good
Yep, all looks brand new. Rotor tight
Not yet. From what I've read that's a hot weather not start, more so then what I'm experiencing. ?
When it happens I've pushed in the clutch (thinking its dead) and grinded the starter
Does the CEL work?
yes, it lights up for a couple seconds when starting
Old Aug 23, 2011 | 08:02 PM
Jasmine1's Avatar
Inspected the main relay and sure enough there are hairline cracks on it. Plan on replacing it tomorrow if I can find one. Hopefully this problem goes away.
Old Aug 26, 2011 | 01:45 PM
Jasmine1's Avatar
Just a little update.
I re-soldered the main relay and the car hasn't acted up since. I was a little skeptical that the relay was the problem given the symptoms, but so far so good. Hopefully it lasts.
Thanks guys.
Old Dec 13, 2011 | 07:42 PM
Jasmine1's Avatar
Well the car went 3 months with out a hiccup after soldering the main relay. Now it's doing the same thing again.
I don't know if resoldering the main relay actually fixed it for those 3 months, or if I have a different issue all to gather. Put the car in storage and have all winter to think about it.
Old Jun 2, 2020 | 11:52 AM
alaskanaking's Avatar
Jasmine1, did you ever figure out how to fix your problem? My 94 Civic VX has the exact same problem. I looked at my relay and it looks OK. The car has a brand new battery. Thanks.
Old Jun 2, 2020 | 04:02 PM
muellersfan's Avatar
9 year old thread. Best to make your own thread. Consider a bad igniter unit.
raider1qaz
10
Jan 30, 2014 07:06 PM
Dc2 Strogg
Oct 25, 2011 04:07 PM
floyd landis
Dec 20, 2010 10:31 AM
weatherall123
Apr 11, 2010 12:26 AM
tarheeler
May 18, 2005 06:19 PM
