Why would a tranny fail if motor oil were to be used?
Old Oct 3, 2002 | 03:43 PM
Mikey's Avatar
Default Why would a tranny fail if motor oil were to be used?
As title says. I'm very curious.
Old Oct 3, 2002 | 03:49 PM
Perfectionist's Avatar
Default Re: Why would a tranny fail if motor oil were to be used? (Mikey)
Automatic or manual? 4th gen manual trannys can use 10W-30. Auto's should use Honda ATF.
Old Oct 3, 2002 | 04:38 PM
Mikey's Avatar
Default Re: Why would a tranny fail if motor oil were to be used? (Perfectionist)
Manaul trans. so in theory, i could just use MOBIL 1 5 or 10w 30
Old Oct 3, 2002 | 05:42 PM
shadowdawn's Avatar
Autos use differnt stuff because the fluid is majorly for cooling, not so much lubrication. A manual's tranny fluid is soley for lubrication like an engine.
Old Oct 3, 2002 | 05:56 PM
Kamin's Avatar
Default Re: Why would a tranny fail if motor oil were to be used? (shadowdawn)
i used motor oil for almost a year in my transmission. worked great. thats what is reccomended if you cant use honda MTF.
but if you can, use honda MTF. its the best.
Old Oct 4, 2002 | 10:33 PM
3rdGteg's Avatar
Default Re: Why would a tranny fail if motor oil were to be used? (KAMiN)
I was told that motor oil would work also so I used it and noticed that my tranny screwed up after about a year on that motor oil; spend the extra $$ on Honda MTF now and save your tranny......some might not agree but just my .02 cents, your choice.
Old Oct 5, 2002 | 10:52 AM
h huff's Avatar
New User
Default Re: Why would a tranny fail if motor oil were to be used? (3rdGteg)
i've been running mobil 1 in my trans for a long while now with no problems. and i drag it at the track like 2 times a month. 5 or 6 passes each time i go.
Old Oct 5, 2002 | 04:14 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Why would a tranny fail if motor oil were to be used? (h huff)
How long are you guys running motor oil for before flushing it and refilling? I always thought that the motor oil would break down quicker than MTF, unless changed regularly. ATF is also different because of the pressure built up, especially in older style vehicles where gear changing is not electronic.
hawjboieg6civic
12
Jul 5, 2010 11:55 AM
yeegsr
24
Dec 25, 2004 08:24 PM
alias 33
Mar 26, 2004 07:33 PM
paybac4223
Mar 12, 2003 04:41 PM
Ri5e
Mar 16, 2002 07:17 AM
