my civic suddenly turns off while driving?
Old Aug 22, 2011 | 04:04 PM
blkciv99's Avatar
Default my civic suddenly turns off while driving?
The car starts just fine, but after about a minute or even a couple of seconds after the car dies engine dies, stereo still stays on. I wait couple seconds to turn the car back on and i wait about a minute or so while its in idle. then the car runs fine. Until the next time i start it. I dont want this to happen anymore so if anyone can help me fix it i would appreciate it. I dont know if this helps but its a brand new abattery i bought it about a year ago. I have subs in the trunk with a amp.
I Have a 1999 honda civic Se.
thanks
Old Aug 22, 2011 | 04:07 PM
Former User's Avatar
Default Re: my civic suddenly turns off while driving?
Have the ICM inside the distributor tested at an auto parts store.
You can use a multimeter to resistance test the coil inside the distributor yourself. See FAQs sticky.
Old Aug 22, 2011 | 04:11 PM
blkciv99's Avatar
if this is not fixed can it become a huuge problem? and if that is the problem will it be expensive to fix?
Old Aug 22, 2011 | 08:00 PM
Do you feel that having a car that won't start or run is a huge problem?
OEM parts from Majestic Honda:
ICM - $172
coil - $86
Old Aug 22, 2011 | 10:35 PM
kalosbg's Avatar
May be "Main Relay" Problem?
but first check ignition coil as RonJ@HT sad.
How to che ignition coil:
Old Aug 23, 2011 | 09:25 AM
NOOdS's Avatar
could possibly be your key ignition, just a suggestion
DirectoryDude
Mar 26, 2012 04:55 AM
LuNcHbOx951
Nov 20, 2010 01:29 PM
95eg6
Aug 10, 2006 09:46 AM
movingIIshadow
Jun 17, 2006 09:43 AM
oOJ-GrindOo
May 10, 2004 05:17 PM
