hi flow cat
Old Aug 22, 2011 | 03:00 PM
civisedan's Avatar
Default hi flow cat
hi,I have a high flow cat and I was wondering if I should put it on my 91 civic sedan or keep the original one on?
is there any pros and cons of a high flow cat?
thanks
Old Aug 22, 2011 | 03:07 PM
4drEF's Avatar
Keyboard Humorist
Default Re: hi flow cat
Most every high flo cat will give you a performance gain as you will have reduced exhaust back pressure.
The downside is that not all of them are constructed to give you a passing result for smog.
The stock 'honey comb" core works fantastic, but is expensive - $300.
A cheap one may use ceramic plate core and doesn't work nearly as well as stock = smog fail.
Old Aug 22, 2011 | 04:05 PM
civisedan's Avatar
thanks for the reply.... i live in ohio and we dont have any emissions testing here so it wont matter if it dont pass a smog test right? so pretty much if i don't want to hurt the enviroment then keep the stock one on but if i want performance gain then go with the high flow.
thankyou again for the info!
Old Aug 22, 2011 | 05:21 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
...or just run a straight pipe ("test pipe")...
Extreez
Jun 29, 2007 06:11 PM
atg1290
Aug 16, 2006 06:35 PM
boosted94teggy
Oct 21, 2005 10:47 PM
88turdbucket
Jan 27, 2005 08:58 PM
VTEC-DA
Sep 4, 2003 12:31 PM
