post your d16z6 SWAP TIPS here
Old Oct 3, 2002 | 02:37 PM
xertechx's Avatar
Default post your d16z6 SWAP TIPS here
I am about to do a d16z6 swap, i was wondering if anyone had any tips when doing this swap to take into consideration, i want to go turbo also.
PEACE ERICK
http://www.geocities.com/xertechx
Old Oct 3, 2002 | 03:11 PM
THE *FOB* MOB's Avatar
Default Re: post your d16z6 SWAP TIPS here (xertechx)
i'm in the process of doing the same thing....just be patient and do it right.
Old Oct 3, 2002 | 03:15 PM
RuthlessEF-9's Avatar
Default Re: post your d16z6 SWAP TIPS here (ssr265)
convert the car to obd 1 so you don't have to worry about fuel maps and vtec engaging. plus the car runs better with the right ecu
Old Oct 3, 2002 | 04:00 PM
Proper's Avatar
Have your friends help you. You can always use the help. And label everything
Old Oct 3, 2002 | 04:10 PM
BoostedED9's Avatar
Default Re: post your d16z6 SWAP TIPS here (SOHC'd up)
dont waste your time doing it...
Old Oct 3, 2002 | 06:09 PM
whizdumb's Avatar
Default Re: post your d16z6 SWAP TIPS here (ED9Hybrid)
damn. that's heavy looking at your sig...
I/H/E didn't even make up for the lost crank HP?
Old Oct 3, 2002 | 06:26 PM
BoostedED9's Avatar
Default Re: post your d16z6 SWAP TIPS here (shiznattik)
nope.... it could also be b/c im not using the p28 ecu but who knows... soon this motor will be turbo and shortly blown then i will move on to better things...
Old Oct 3, 2002 | 07:19 PM
MrTodd's Avatar
Which ECU are you using then? (Guessing PM6) How are you activating the VTEC?
If you get a Zdyne conversion (easiest route, vs. obd-1 conversion) they'll put in the proper Z6 fuel and timing maps in there. You could gain a bit of HP - but look at your torque numbers! If those numbers are at the wheels, then that's better than any ZC or B16.
Old Oct 4, 2002 | 04:07 AM
BoostedED9's Avatar
Default Re: post your d16z6 SWAP TIPS here (MrTodd)
im using a apex vafc and crx si ecu, and those numbers are SAE corrected @wheels... oh yea, and with my silencer in i hit 108tq but lost 1hp... i can always put it bck on the dyno and mess a round with it some more...my timing is set at around 17-18deg...
[Modified by ED9Hybrid, 8:09 AM 10/4/2002]
Old Oct 4, 2002 | 05:34 AM
91sifreak's Avatar
New User
when I did this swap, I used the stock pm6 ecu for the swap to keep the Si Dist and used an RPM activator switch with a 4800 rpm pill in the box, then got a ride in one that had the right ecu and dist and it was alot stronger, better maps......
Old Oct 4, 2002 | 08:14 AM
USDM 4G VTEC's Avatar
unless u get a Zdyne 1 wire ECU....
i tell u to do the OBDI conversion and run the P28....
or go cheap use a PM6 or PG7 and a APEXi VTEC controler....
check my sig... that link might help u...
Old Oct 5, 2002 | 04:55 AM
civicwagonman's Avatar
Default Re: post your d16z6 SWAP TIPS here (JDM EF9)
I am running pm6 on mine. had p28 wired for about two months but couldn't get it to run right all the time. had a driveability problem. pulled a little more with the p28, but still nothing like my 90 ex 4dr with 161K on stock everything. NOTHing like it. not happy at all with the d16z6. i've never ridden in a zc motored civic, but curious how much **** it has. either going zc or b16 on my next project.
kris9
Feb 18, 2010 01:48 PM
low-1
Jan 23, 2010 12:30 PM
RedRevolver
15
Dec 10, 2008 06:15 PM
TehMoonRulz
Apr 4, 2005 06:38 PM
dragonhaven2001
May 26, 2003 01:39 PM
