stripped coolant bleeder bolt...what are my options?
Old Aug 20, 2011 | 12:29 PM
wtsapexipowerfc's Avatar
Default stripped coolant bleeder bolt...what are my options?
my friend striped the coolant bleeder bolt that goes into the thermostat housing when he was tightening the bolt during coolant change....
what are his options?
what is the thread pitch of the hole?
Old Aug 20, 2011 | 12:32 PM
Former User's Avatar
Default Re: stripped coolant bleeder bolt...what are my options?
What year and engine?
The bleeder bolt is located on the water outlet cover, not the thermostat housing. The easiest fix may be to just replace the water outlet cover.
Old Aug 20, 2011 | 12:33 PM
its a d16z6.. 92 to 95.. ?
Old Aug 20, 2011 | 12:37 PM
I think the diagram answers your questions.
Old Aug 20, 2011 | 12:42 PM
are all d series thermostat housings interchangeable?
strategy400's Avatar
Probably should replace the water outlet. Don't want to mess with your cooling system.
You could remove it and rethread for a larger bolt to plug the hole, but by then you've spent money on drills and taps and removed the thing, might as well buy a replacement part...
Old Aug 20, 2011 | 12:43 PM
sorry i mean it is the water outlet cover
its the bleeder bolt that is up near the top coolant hose isnt this the thermostat housing
Is this a separate question because, again, the bleeder bolt is NOT screwed into the thermostat housing.
Old Aug 20, 2011 | 01:54 PM
ok it is the bleeder bolt
Swansen
Jun 15, 2015 03:26 PM
Root of all Evil
Oct 29, 2011 09:54 AM
tico
May 11, 2009 03:16 PM
OogalyDoogaly
Honda Motorcycles
Feb 4, 2008 05:31 AM
CoolRedXylophone
Apr 30, 2006 06:59 AM
