93 Del Sol A/C problem
Old Aug 19, 2011 | 07:28 PM
VIDC2's Avatar
Icon2 93 Del Sol A/C problem
in my 93 sol, i just replaced the pressure switch, and when i turn the a/c on, I get nothing, When I jump the switch i get nothing, when I jump the switch and ground it, fans and compressor come on and a/c gets ice cold.........what can that be?
Old Aug 19, 2011 | 07:32 PM
Former User's Avatar
Default Re: '93 del Sol - A/C - Pressure Switch Question
If you ground the same Blu/Red wire at the rear of the heater control panel, does the A/C again turn on and blow cold?
Old Aug 19, 2011 | 07:35 PM
VIDC2's Avatar
let me check that one sec
Old Aug 19, 2011 | 07:41 PM
VIDC2's Avatar
how do i get to it? without breaking anything that is...it's my first sol and first time ever touching one...
Old Aug 19, 2011 | 07:46 PM
The diagram is for a Civic. Maybe the Del Sol is similar?
Old Aug 19, 2011 | 07:50 PM
VIDC2's Avatar
well the console is totally diff....i will have to look for it...but if i ground it and it works, what will that mean/ and the opposite?
Old Aug 19, 2011 | 07:52 PM
If the A/C works, the heater control panel is bad. If it doesn't work, the A/C thermostat may be bad, but more tests would be needed to verify.
Old Aug 19, 2011 | 08:00 PM
VIDC2's Avatar
would that mean the thermal switch on the compressor? (a/cthermostat)
Old Aug 19, 2011 | 08:01 PM
No. The A/C thermostat plugs into the evaporator behind the glove box.
Old Aug 19, 2011 | 08:25 PM
VIDC2's Avatar
Default Re: 93 Del Sol A/C problem
how can i troubleshoot it?
Old Aug 19, 2011 | 08:30 PM
Do the first test and go from there. In the meantime, you could also test whether the A/C turns on when you ground the Yel/Wht wire in the A/C thermostat connector.
Old Aug 19, 2011 | 08:39 PM
VIDC2's Avatar
just found the problem...my car didnt have a glove box when i got it, so i looked and saw that there is a connection (2 wire) right behind it that was unplugged and hidden.......pulled it out and connected it and everything worked perfectly! thanks to you showing me where to look..thanks a million!
Old Aug 19, 2011 | 08:58 PM
sissyphean
Jan 12, 2019 09:03 AM
Roosterjd
15
Apr 15, 2016 07:50 AM
mcq_dolla
Feb 10, 2009 05:45 PM
iunchb0x
Feb 14, 2006 08:41 AM
