B16A1 Dyno
Old Oct 3, 2002 | 01:37 PM
Driven's Avatar
Default B16A1 Dyno
my CRX got dynoed.
134hp@7500rpm
101tq@5600rpm
HP calculator is pretty close:
Car weight with driver - 2220lbs (car without driver - 2051lbs)
16.5lbs per wheel horsepower
Assuming 15% drivetrain loss, I'm making close to 160hp to the crank (stock engine specs)
Assuming 20% drivetrain loss, I'm making close to 170hp to the crank.
13.8lbs per crank horsepower for 15% loss, 13.0lbs per crank hp for 20% loss.
I'll scan the dyno in sometime. The torque path stays between 80ft-lbs and 100ft-lbs from 4400rpm-8200rpms.
The hp is above 100hp between 5400rpm-8200rpms.
I revved it to 8500rpm. At 8500, i'm making 120hp/70ft-lbs. Theoretically, I should shift right after 7500rpms since after that, I'm not making anymore power.
Between 7500rpms-8200rpms, the hp stays above 125.
engine mods:
B16A1, cheap dirty air filter, DC Sport 4-2-1 header, B&M FPR set at 42psi, custom exhaust, and a chipped ecu.
Overall, i'm happy with it. I was hoping for at least 140hp... but, considering the wear on the engine (high revving, autocrossing, road events, etc) i guess it makes sense.
Old Oct 3, 2002 | 02:48 PM
incubus's Avatar
Default Re: B16A1 Dyno (Driven)
you are putting up good numbers for an A1, driven. my rex is prolly running around the same, I have the same upgrades. only difference is my car weighs in @ 1955 with me in it.
Old Oct 3, 2002 | 03:25 PM
keithv's Avatar
Default Re: B16A1 Dyno (incubus)
not flaming or hating here, but those numbers seem kind of weak to me, especially with some mods. but i guess ragging on it like you have is accounting for some of that.
my stock zc put out 117whp and 98 ft-lbs. no wonder those two motors are pretty close in 1/4 mi times...
Old Oct 3, 2002 | 04:12 PM
Driven's Avatar
Default Re: B16A1 Dyno (breaka_1_9)
Well, if you consider how hard the engine has worked, it's perfectly understandable.
stock, the crank hp is 160hp. the engine is used when i got it with god knows how many miles (20K-40K?). Then, I road race it and autocross it to death. I rev it constantly to 8500rpm and stay in VTEC as long as i possibly can.
plus, the mods aren't really that much. a header isn't worth 10-15hp like people say. an intake is 1-2hp on a dyno. the FPR just helps tuning, making the 160hp more available. the chipped ecu does the same. So, considing wear and tear... and the mods added, it's right around normal.
_____
and how'd you get your 91 Hf to weight under 1900lbs with a b16? Was this professionally weighed? Do you have a cage? I think my B16 and Cage killed the weight advantage i would have had with a HF.
Old Oct 3, 2002 | 04:34 PM
kHoA DoGG's Avatar
ARE you serious!!! I have the same setup and around the same wear and tear milage. Geez... time for a new motor swap... and I still have the full interior and stereo. Man...
Old Oct 3, 2002 | 06:22 PM
chri5's Avatar
Default Re: B16A1 Dyno (sNoOzin' EF9)
maybe I'm high, but I always swore you had installed cams in it at one point?
:mumbling:i need to start taking notes on stuff i read about people's cars online:mumble:
Old Oct 4, 2002 | 12:18 PM
Driven's Avatar
Default Dyno Sheet
Old Oct 4, 2002 | 12:39 PM
Naij's Avatar
did you upgrade your valvestrians? 8.5 is kinda high for stock
Old Oct 4, 2002 | 03:04 PM
Malgerus's Avatar
Default Re: Dyno Sheet (Driven)
You're right about where you should be, considering the way you drive your car Very nice.
Old Oct 4, 2002 | 03:30 PM
StorminMatt's Avatar
I would seriously consider buying a good intake. This could very well be the cause of your low power output. Believe me, this makes a HUGE difference on a B16A. Especially if you are still using the stock airbox.
[Modified by StorminMatt, 12:30 AM 10/5/2002]
Old Oct 4, 2002 | 09:26 PM
SiR Kid's Avatar
New User
Default Re: B16A1 Dyno (StorminMatt)
Wow. With just ITR cams and an ITR intake manifold I made 151 at the wheels through GReddy exhaust on my b16a1. I didn't have an intake either, just a K&N ont he throttle body, which dyno proven <borrowed an intake> lost me 3 HP across the board.
I was using a stock exhaust manifold, too, though.
Trust me, my car DID NOT have an easy life either I shifted the a6 at 7200, and the B16a, I'd rev til the limiter ALL DY EVERY DAY at 8200, then with my Hypertech tuner, I revved it to 8500 ALLLL the time
Old Oct 5, 2002 | 01:54 AM
CRXSleeper's Avatar
Default Re: B16A1 Dyno (SiR Kid)
That number is right. I bet if you get some good cams and tune the hell out of the engine, you will get another 10-15 HP to the wheels easy.
Old Oct 5, 2002 | 03:33 PM
I also could not help but notcie that you have a custom exhaust. I myself am not a fan of custom exhausts. In 99.999% of cases, they are not done right. They typically have crush bent tubing. Sometimes, they even use the stock tubing to the axle. And they often have a cheap, restrictive, chambered type muffler. You might want to ditch this as well. If you get a good exhaust system and a reputable intake, you could very well be pusing 140+WHP.
Old Oct 5, 2002 | 05:02 PM
Driven's Avatar
high horsepower at WOT at 8000rpm isn't benefiting the low-rpm torque that i need...plus, i can't STAND open exhaust 4 cylinders. I have a 3 chamber muffler to quiet the engine and to help improve some low-end push...which helps me power thru slow speed turns.
and yes, it's crush bent!!
Old Oct 5, 2002 | 08:31 PM
Blown90hatcH's Avatar
What ecu is in there. Did you try the stock one. On all the OBD0 electronic cars, the ones we dynoed with a chipped ecu made less power than the stock Pr3 ecu.
J
prelude_93vtec
Nov 19, 2007 01:31 PM
xstalkrx
Sep 17, 2003 07:08 PM
Odessa
Jul 28, 2003 08:39 AM
Project_SOHC_EX
Dec 5, 2002 05:50 PM
Ross
Aug 19, 2001 09:05 PM
