car not starting
Old Oct 3, 2002 | 01:26 PM
98cwtypeR's Avatar
Default car not starting
ok, it's not my car..but a buddy of mine is having problems with his car. He turns the key and tries to start the car, but nothing happens. No action, doesn't even struggle or anything. Just wondering what could be the problem...any kind of help would be greatly appreciated..oh yea..but his lights turn on and everything, it's just when he turns the key nothing happens.
Old Oct 3, 2002 | 01:42 PM
SPOCK's Avatar
New User
Default Re: car not starting (98cwtypeR)
if you can hear the fuel pump turn on then you should have enoungh power to at least crank the engine. check to see if the starter is connected right. check all your grounds. i had a simular problem. my car would not start because a ground was loose. another dumb mistake i made was that we put the map sensor where the tps was and vice versa. the car would try to turn but no start. make sure your pluged in all the right places.
Old Oct 3, 2002 | 01:50 PM
98cwtypeR's Avatar
Default Re: car not starting (SPOCK)
ok, ill check that...thanks
Old Oct 3, 2002 | 02:08 PM
98cwtypeR's Avatar
do you think a starter kit would help?
if so, how much do they run for..?
Old Oct 3, 2002 | 02:46 PM
Mikey's Avatar
Well, you might want to start with the simple things first. Test volate coming out of the battery. Then it's time to move onto the more expensive things such as the starter, fuel pump, etc.
ILUVTEC
Mar 20, 2010 01:31 PM
Fresh Ej2
26
Apr 2, 2009 06:19 PM
91greenbeast
19
Sep 30, 2008 09:09 AM
IntegraPir4te
Mar 19, 2007 10:51 AM
Audio28
Jul 3, 2003 05:33 PM
