A Simple Question.
Old Aug 18, 2011 | 10:37 PM
Theuri's Avatar
Default A Simple Question.
Hey guys I just started taking my time learning more about engines and how they work. I got an EG hatch not long ago and I'm starting to mod it. I was reading about camshafts and have a question. If you change camshafts would you not also have to change the timing belt or adjust when then spark happens? Thanks in advance for the answers.
Old Aug 18, 2011 | 10:39 PM
98civdx's Avatar
Master Detailer
Default Re: A Simple Question.
Depending on how new the belt is, I would change it, simply becuase you are already in there, you might as well as well do it then. Along with water pump, tensioner. This is assuming they haven't been replaced recently.
You can't adjust the spark. You can adjust the timing, but that is all I know of.
Old Aug 18, 2011 | 10:53 PM
Theuri's Avatar
Well I was planning on replacing most everything with new parts anyways because I don't know when they were last changed. Thanks for the reply. I'll be taking my time might as well get as much done while at it.
Old Aug 18, 2011 | 10:55 PM
98civdx's Avatar
Master Detailer
Go OEM on parts such as those. Trust me, it's worth the extra bit of money.
Old Aug 18, 2011 | 11:00 PM
boostedef123's Avatar
You can adjust the timing via the distributor bolt. Just loosen it and turn the cap. How do you think ignition timing is set?
Old Aug 18, 2011 | 11:31 PM
virgineg6's Avatar
What engine in the car right now? If its stock dont waste your money, better off doing a swap
Old Aug 19, 2011 | 02:20 AM
Former User's Avatar
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post.
zztrent
Honda Civic (2001 - 2005)
Nov 4, 2010 11:27 AM
B serious
Jan 4, 2008 04:06 AM
DC2Integ01
Mar 19, 2007 05:02 PM
PetroGuyX
Jul 30, 2003 12:29 PM
Nocturnal
Apr 13, 2003 05:41 PM
