Swap ideas? What do think?
Old 08-18-2011, 09:42 PM
natedog95eg's Avatar
Icon2 Swap ideas? What do think?
I just purchased a 95 DX coupe and thinking of going Built B18B LS Turbo/ GSR trans with the hopes of going LS/Vtec wit a B16B head or just a B16A Head with Civic type r cams, cam gears, etc. Decided to go wit the LS motor because some boys put a B20B/B16 J1 tranny in my old 93 Integra Integra LS Special and screwed the swap up! Idle was terrible and everytime it was in neutral just kept revving up on it's own and they couldn't fix it! Also heard the LS block stock can handle more psi boosted than the CRV block, which means I would have to sleeve it and I am to cheap for all that right now. Anybody have any other ideas on a setup that a broke dude like me could do??? Feel free to help me out!!
Old 08-18-2011, 09:54 PM
Master Detailer
98civdx's Avatar
Default Re: Swap ideas? What do think?
The B20/B18A/B are basicly the thing, if they screwed the swap up, it's not due to the engine choice, it's due to the lack of skill and/or stupidity.
The LS has been said to hold a little more Psi/power then a b20, due to the b20's thinner sleeeves. This is due to the fact it's a 2L.
How much HP are you aiming for? Keep in mind, PSI doesn't really mean much.
Also, what is your budget? And, keep in mind, if you do not search or at least try and help your self find some of this information out, many will not help you. Or atleast the amount of usefull info will be less. You NEED to search, this has been covered a million times.
Old 08-18-2011, 10:45 PM
NotAJDMFanBoy's Avatar
The B20 does have thinner sleeves, but also being a larger diameter, it will have a larger surface area for the pressure to act on. And the wider pistons will have more of a tendency to rock.
But agreed, you need to search.
Old 08-18-2011, 10:48 PM
civic_rookie's Avatar
b20 v tech is the way to go
Old 08-19-2011, 01:04 AM
DO/\/\O's Avatar
Go B18 Turbo with lsd transmission
Old 08-19-2011, 03:32 AM
Ek Forever y0!
Libertariat's Avatar
You could always fix the current swap and rebuild the bottom and and make a beast n/a. 220whp and 160tq is pretty doable on a reasonable n/a build.
em1gangsta
01-20-2009 10:48 AM
Knucklehead7
11-11-2007 07:09 AM
STP_crx123
11-18-2005 06:49 PM
Sassafrass
01-08-2003 12:41 PM
bad 2 the B-ONE ej1
10
11-25-2002 01:40 PM
Quick Reply: Swap ideas? What do think?
