Rear Windscreen washer not squirting water
01 DC2R.
When i hit the switch on the stalk i can hear the motor running but no water comes out. The front washers work fine and spray heaps of water, the back however sprays nothing. Now, i disconnected the washer water line in the engine bay and tried again, and only a little was trickling out of the hose which leads to the back washer, but water coming out of the front washer line is almost gushing out! Any ideas why the pressure coming out seems of the rear one is low? There isnt a secondary water bottle is there? i presume not as both hoses lead to the same bottle. Motors (both) sound healthy. I also cannot see any leaks coming from anywhere.
Thanks
Thanks
Nevermind, all sorted turned out to be a blockage. I just filled both sides of the line with compressed air and tried the washer again and it worked. The rate of water coming out of the line is substantially higher too
