5-Speed tranny fluid...I know Im not a complet retard!!!
Old Aug 18, 2011 | 03:59 PM
stella88's Avatar
Default 5-Speed tranny fluid...I know Im not a complet retard!!!
Seriously I know Im not a complete retard, and I know I need to fill the transmission where the Speedo cable goes in. I've tried a tube over the hole, and two different methods of inside the hole. And Every single Fvcking time the Fvcking shizt drips out of the fvckin hole where I was pouring the tranny oil into. If Im missing something so Flippin obvious PLEASE PLEASE hit me with a Stupid Stick
Old Aug 18, 2011 | 04:02 PM
BiG ChOr!Zo's Avatar
Default Re: 5-Speed tranny fluid...I know Im not a complet retard!!!
your supposed to fill it in the fill hole located on the passenger side housing not through the vss hole...!!!
http://www.youtube.com/watch?v=Tj5xTXRK9OI
Old Aug 18, 2011 | 04:08 PM
stella88's Avatar
Ok...I thought you needed a hand pump for that location. Im assuming you hold the funnel sorta like a beer-bong & just squirt the shiznit in??
Old Aug 18, 2011 | 04:09 PM
Tyson's Avatar
yeah i dont understand why ppl would use the wrong hole to fill the tranny as the first option. id only consider it if the NORMAL fill bolt was completely stripped and had no other way to get fluid in. but i think its even easier to just take the axle off and fill that way if i had to.
use a 17mm SIX POINT box end wrench. nothing else. no 12pt. certainly not an open end. or you will likely strip that bolt, and THEN youll be looking for options...
Old Aug 18, 2011 | 04:12 PM
you can use a $5 plastic hand pump from kragen...thats what i use to fill mine...!!!
Old Aug 18, 2011 | 04:23 PM
JDpower's Avatar
I dont care ill still fill mine throught the speedo. I think its easier if you dont have anything to pump oil in, just use gravity.
Old Aug 18, 2011 | 04:36 PM
KINGVEM^^ED6's Avatar
smh use the fill hole
Old Aug 18, 2011 | 04:48 PM
stella88's Avatar
for everybody thats persistant the oil wont go thru the vss location Im a FVCKIN IDIOT & cant use text quote................Tyson exactly which 17mm bolt are you talkin about??
Old Aug 18, 2011 | 04:49 PM
stella88's Avatar
and I prob will use the fill hole.
Old Aug 18, 2011 | 05:31 PM
turbostd's Avatar
I use the reverse sensor hole on my crx as the fill plug is so messed up I cant get it out.
Old Aug 18, 2011 | 05:38 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
There is only one fill hole and one drain hole... The fill is right next to the passenger side axle - only one 17mm head bolt there - can't miss it. The drain is a 3/8" ratchet (inverted square) and is at the bottom of the transmission passenger side. Only one of these as well - can't miss it...
If you use any other hole you risk having problems from over filling... These can be as simple leaks all the way to burning up bearings inside the transmission from aeration of the fluid... Don't be a fool, use the right hole - or she might just slap you in the face.
Old Aug 18, 2011 | 05:48 PM
some like it
Old Aug 18, 2011 | 05:56 PM
90_EX_Civic's Avatar
i use the breather tube
Old Aug 19, 2011 | 04:50 AM
FF for Life's Avatar
As N3va3vaSatisfi3d said, its on the passenger side, on the back side right next to the axle. Its easyest to break torque on that 17mm from below it and easyest to fill from the top with a hose shoved onto a funnel, make sure there is room for air to get out or you will have spillage. Its full when the fluid level is at the fill hole.
Old Aug 19, 2011 | 07:52 PM
stella88's Avatar
cool thanks guys, I ended up doin what 2 or 3 of you sugested, and filled it where the fill hole was with a long *** hose & funnel hanging from my hood. I may not have had enougfh fluid (some spilt on the ground VSS location before I got a pan under it)I used 75w-90 Valvoline high performance gear oil, since I was too cheap to buy Royal Purple whiched I used when I did my engine swap, seemed to work great. I do realize Im supposed to use 10w-30 Just figured the valvoline would hold up better...thats it for now!
Old Aug 19, 2011 | 08:09 PM
Tyson's Avatar
no, i dont think thats any better.
im not a fan of using 10w-30 over PROPER honda MTF (which has tranny specific additives), but you should have just used engine oil.
ppl generally dont get good results with straight gear oil. its not made to use such a heavy oil.
Old Aug 19, 2011 | 09:14 PM
stella88's Avatar
ok thanks!
Old Aug 19, 2011 | 09:26 PM
88h22_CRX's Avatar
Yea stay away from gear oil. It's way too thick. I'd be surprised if you could even get the gears to engage. It's not worth the risk.
Old Aug 19, 2011 | 11:13 PM
dreadhead89's Avatar
When u tried filling it threw the vss you did take the vss out of the tranny before u did this? and didnt try fillin the tranny up threw the speedo cable insert hole? Iev alwasy filled my trannys up b,d,obd0,obd1 dosent really matter. Ive found it the easiest and less messiest. So something is not goin right for you!
Old Aug 20, 2011 | 02:12 PM
zrickety's Avatar
10w30 is recommended in the manual, that's what i've been using for about 90,000 miles
Old Aug 20, 2011 | 02:27 PM
turbohatchBnuts's Avatar
i use honda manual transmission fluild in all my hondas .
zombieD
Sep 16, 2008 02:33 PM
ef dino
Dec 16, 2006 06:42 PM
sting94112
Feb 22, 2004 01:38 PM
hatchy
Aug 26, 2002 08:31 AM
wizzards581
Apr 5, 2002 10:20 AM
