ls crank gsr block helpppp
Old Aug 18, 2011 | 02:04 PM
GSR615's Avatar
Default ls crank gsr block helpppp
Well I took my gsr block to the shop to get it built and now they are staying the motor ,won't spin.
B18c block
B16 pistons nd new rings
Ls crank nd rods
New bearing ,oil pump ,water pump.
They said they put the motor together but it won't spin , what would be the problem .
Old Aug 18, 2011 | 02:09 PM
m_shake's Avatar
Default Re: ls crank gsr block helpppp
what are the bearing clearances??
Old Aug 18, 2011 | 02:17 PM
GSR615's Avatar
i have no idea , im letting my local machine shop assemble the bottom end, they called me today after like 2 weeks saying that they put the motor together and it would spin..
they said either the crank or the block is bad..
honestly i think its the clearances but i thought the machine shop, would of figure that out tho..
Old Aug 18, 2011 | 05:33 PM
PyroProblem's Avatar
Find a new machine shop ASAP. If they cant tell you whats bad, they shouldnt be messing with engines at all...
And you think they would have caught the clearances being too tight if they had measured it...
Common sense tells me to loosen up the main caps and see if it will spin then.
Old Aug 18, 2011 | 06:12 PM
CRuNCHyEM1's Avatar
Prolly hitting oil squarters. Replace them with bolts or buy the Eagle kit
Old Aug 18, 2011 | 07:33 PM
Reyke's Avatar
so let me get this straight you took your engine to a machinist to have them assemble it for you and they are saying it is seized and they don't know why, I mean are they stupid or something, it's not rocket science.
I personally would go pick my engine up, unanounced of course and take my engine from those incompentent fools and take your business elsewhere.
If you don't mind me asking when they called you and told you it was siezed what did they suggest, did they try and sell you more work and time in your engine???
Old Aug 18, 2011 | 07:46 PM
From what I've seen, they just hit a little with an 89mm crank... Not quite enough to prevent the engine from turning over at all, but this IS a concern that the machine shop probably has no idea about..
Get your engine away from them ASAP before they do something stupid like increase the bearing clearances with a dremel.
Old Aug 18, 2011 | 10:04 PM
GSR615's Avatar
Thanks for all the info ..I'm going to talk to them tomorrow and get some more info
Old Aug 19, 2011 | 04:41 AM
kyden's Avatar
this is scary that a machine shop can't figure it out.
Old Aug 19, 2011 | 05:53 AM
CHEETAH's Avatar
I agree...or loosen the main bolts one journal at a time as that can tell you if the crank is bent.
Old Aug 19, 2011 | 11:02 AM
GSR615's Avatar
i went to the shop today , they say that i need a line hone because the motor had a spun main bearing..
hopefully this fixes it because im tired of waiting for my motor ..ill keep you guys updated..
would anybody drive around on the gsr/ls motor aafter it been built or should i let it sit and go get a tune ?
Old Aug 19, 2011 | 11:05 AM
kyosoeg6's Avatar
why would they not notice/tell you this before the motor was assembled. either that "machine shop" is not competent enough to be called a machine shop or your relaying info wrong.
i dont think ive seen a honda spin a main bearing . im trying to think back
Old Aug 19, 2011 | 11:14 AM
Builda'Teg_92's Avatar
Usually the case.
JDM Lyfestyle
May 4, 2009 08:30 PM
dfoxengr
Apr 8, 2005 06:04 AM
Shelton
May 5, 2004 10:58 PM
PhantomRacerGSR
Mar 16, 2003 04:49 AM
xJ.SLOTHx
Sep 22, 2002 09:33 PM
