2000 civic si passenger side door won't lock
i have a 2000 civic with power doors and a clifford... it worked fine but one day i heard a loud noise coming from the door when it locked... now the door wont lock at all... not with the key,alarm or door switch... what could it be? is it the actuator? help please...
My drivers side door is the same way. I took the door panel off and tried to move the metal rod... it won't budge. I think my lock cylinder is frozen.
when i move the actual rod it works fine... if i hit the clifford button it will lock and unlock for like 5 times then it will just stay unlocked...
i took the original one off today to replace it but i cant put the new one on... it has 3 screws holding it on but theres a little lever that needs to be on which i cant seem to put since its at an uncomfortable location... should i just remove the latch?
It is a pain, you have have attach it to the latch and then position it back into the door and then align the screws. There is room but very tight, you need patience to do it.
so it is possible to do without taking out the latch? i tried this morning and even removed the window rail to give me more room but i cant seem to put the little lever on the latch...
No take the latch and actuator out together, take off the old actuator put new on then put back in.
Tell me how it works out for you, plus removing or pushing the window channel helps too, like you said you did.
very helpful! i did it this morning... it was a mission because i had to take off the exterior door handle to remove that rod thats attached to the handle... once i removed that it was cake... thanks for everyones help... glad theres a forum where people can get helpful info and not everyone bashing on everyone...
dimsumjim
Apr 11, 2015 10:37 PM
young geezer
Jan 21, 2011 03:26 AM
Intercooler
Nov 18, 2004 08:43 PM
