98 Civic with clutch problems
Old Aug 18, 2011 | 01:24 PM
Devers's Avatar
Default 98 Civic with clutch problems
New to the site, as this is my last alternative to my problem... Don't know what else to do.
YEAR: 1998
MAKE: Honda
MODEL:Civic EX 4DR
ENGINE: B18C1 (GSR)
TRANNY: GSR Tranny
Ok, So recently I've been having trouble with my clutch, (Grinding, not going into gear etc.)
Took the car to my friends house, he check the fluids, they were all topped off, he did notice that the clutch pedal had clutch fluid on it, and requested that I should replace the clutch master cylinder, being that there's a leak, my system had air and no pressure was building, so it was basically like I was "Shoving" the shifter into gear.
So, I did just that, bought a new cylinder, replaced it, bled the system, and the shifter still won't engage from a dead stop. The car "jerks", "stalls out" but will eventually (Playing with the shifter for 15 minutes.) get into gear, once in gear the car will shift very smoothly, no grinds at all. I'm running out of options, I don't have the funds to take the car to a professional, but if that's what it comes down to I'll have to pull $$$ out of my ***, and It'll most likely be costly.
Any tips or suggestions would be much appreciated,
Regards, Mike.
Old Aug 18, 2011 | 01:29 PM
Devers's Avatar
Default Re: NEED URGENT ASSISTANCE!!!
Wrong section? So I've reposed the thread, Thanks.
Old Aug 18, 2011 | 01:52 PM
grumblemarc's Avatar
The Grumpiest
Clutch cylinder? How do you get fluid on the clutch pedal? Did you replace the master or the slave? YOu also would want to start titling your posts to be a liitle more specific than "HELP!" as per the forum rules.
Old Aug 18, 2011 | 02:02 PM
Devers's Avatar
My apologies... I've replaced the Slave.
Old Aug 18, 2011 | 02:13 PM
The Grumpiest
If there is fluid on the clutch pedal you might want to inspect the master as well. I've heard of these leaking but not to the point that they leak onto the pedal assembly.
Old Aug 18, 2011 | 02:20 PM
tlarimer's Avatar
They will leak onto the pedal if the seal is shot, I have seen it once or twice over the years.
OP, replace the Master cylinder and rebleed the system.
Old Aug 18, 2011 | 02:34 PM
Devers's Avatar
The clutch master cylinder is the one that actually attaches to the pedal or is that the slave? I'm a little new at this, so...
Old Aug 18, 2011 | 02:36 PM
The Grumpiest
That must suck if you've got new kicks.
Old Aug 18, 2011 | 02:39 PM
Devers's Avatar
Sorry it's the clutch master which i've replaced.. sorry for the confusion.
Old Aug 18, 2011 | 02:40 PM
The Grumpiest
Then inspect the slave.
Old Aug 18, 2011 | 02:45 PM
tlarimer's Avatar
Ditto, make sure the hydraulics are not leaking internally/externally, if in doubt, replace the slave, it's something like $25.
Old Aug 18, 2011 | 02:54 PM
Devers's Avatar
Will do, thanks.
Old Aug 18, 2011 | 05:37 PM
Former User's Avatar
Default Re: 98 Civic with clutch problems
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post. Title edited.
GR_DC2
Jan 23, 2012 09:07 PM
Devers
Transmission & Drivetrain
Aug 18, 2011 03:55 PM
95greenteg
Apr 10, 2006 06:53 PM
thehatchninja
Apr 13, 2004 04:37 AM
Cheeks153
Oct 25, 2003 02:18 AM
