coilover sleeves crooked on oem front perches
Old Aug 18, 2011 | 05:03 AM
mhewitt's Avatar
Default coilover sleeves crooked on oem front perches
I bought some coilover sleeves for my civic and I'm runnin them with eibach springs on oem struts but the front struts have a spring perch on them that doesn't sit flat. So the sleeve will only touch half of the perch it sits on because it is flat, unlike the perch. Has anyone ever ran into this n what did u do to fix it?
Old Aug 18, 2011 | 05:27 AM
grumblemarc's Avatar
The Grumpiest
Default Re: coilover sleeves crooked on oem front perches
Pics. Are these Ebay type coilovers? Are these regular lowering springs or are these made to go on sleeves?
Old Aug 18, 2011 | 11:57 AM
mhewitt's Avatar
Yes they r ebay type. The springs are regular lowering springs but they are not the pro LEM its where the coikovers sit on the perch on the front springs.
Old Aug 18, 2011 | 11:58 AM
mhewitt's Avatar
Problem*
Old Aug 18, 2011 | 12:05 PM
The Grumpiest
Yeah. That won't work. Also you need O-rings to have the sleeves fit straight on the shock.
Old Aug 18, 2011 | 12:41 PM
mhewitt's Avatar
It came with o rings but I was only concearned with where the bottom of the sleeve sits on the perch
Old Aug 18, 2011 | 12:45 PM
The Grumpiest
Hence the reason that your sleeves sit crooked. The O-rings need to go up and down the length of the sleeve on the shock to keep the sleeve straight. There is no "fix". On top of that, regular lowering springs are not meant to be used on coilover sleeves. That combo could prove prove to be dangerous.
Old Aug 18, 2011 | 03:37 PM
sde780's Avatar
You're using stock struts, Eibach lowering springs, and sleeves from an ebay kit? Why not just ditch the sleeves and just install the lowering springs on the stock struts?
Old Aug 18, 2011 | 03:58 PM
The Grumpiest
That's what I'm saying.
hugebob
May 21, 2012 09:10 PM
cjmvtec
Suspension & Brakes
Apr 7, 2011 03:47 PM
liquidx
Sep 12, 2007 09:05 AM
nk2k2
Apr 18, 2006 05:17 PM
VWkila
Jul 2, 2003 07:39 PM
