f22b1 swap civic
Old Aug 17, 2011 | 04:43 PM
team_lunatics's Avatar
Default f22b1 swap civic
Hello everyone,
I have a 93 civic hatchback swapped with a f22b1 motor. The f22b1 came out of a 95 accord ex. Its rebuilt and bored out to 87mm. The oem spec is 85mm. I got it to start, but the only thing is that it will not idle over 3000 rpm. The car will drive and go into gears, but cant go over 3000rpm. May it be that its not getting enough fuel? Anyone with any suggestions will be appreciated. Thanks.
Old Aug 17, 2011 | 04:52 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: f22b1 swap civic
CEL codes?
grumblemarc's Avatar
The Grumpiest
It's not supposed to idle over 3K. Now revving past 3K is a different story. Are you getting any CELs? This really should go in the Hybrid forum. Correct ECU?
Old Aug 17, 2011 | 05:37 PM
Yes it does have cel. Im just using an auto p28 to get the car started. By the way, it was an auto car, but i converted it to 5 speed. Im pretty sure i did the auto to manuel correct because it started on the first try. Would the auto p28 make the car not go over 3000 rpm?
Old Aug 17, 2011 | 05:46 PM
The Grumpiest
Running an auto ECU on a manual car would be a problem. Are you sure a P28 is the right ECU to be using? What CEL is it throwing?
Old Aug 17, 2011 | 05:55 PM
yes i believe so.
Old Aug 17, 2011 | 06:08 PM
hondamark35's Avatar
Originally Posted by team_lunatics
...i converted it to 5 speed. Im pretty sure i did the auto to manuel correct because it started on the first try.
i would say you missed one step, sourcing a 5spd ECU.
the auto ECU is seeing "faulty/disconnected plugs" where the trans. should be and going into limp mode. get the right ECU and see if you still have any problems.
Old Aug 17, 2011 | 06:13 PM
on second thought, pull the codes first to be sure. i would expect them to be somewhat related to the transmission. if not, double check your wiring and confirm 100% that the P28 factory tune will work with the F22 (that would surprise me if the factory tune ran well... and i'm assuming this because you didn't say "chipped P28")
Old Aug 18, 2011 | 06:39 AM
Yea will do. Will let yall know what happens. Thanks a bunch.
Old Aug 18, 2011 | 03:46 PM
Hell yeah. It works. I used a manuel p28 ecu and it runs great now. Thanks to everyone who helped. Thanks a bunch.
eh2_Trav
Oct 26, 2017 02:14 PM
turbotime
43
May 5, 2014 04:52 PM
dubbedcorde
12
Dec 5, 2004 07:59 PM
Bailhatch
May 23, 2004 07:36 PM
turbotime
Nov 29, 2003 03:53 PM
