B20 Vtec timing belt?
Old Aug 17, 2011 | 10:54 AM
JDMeGGaLLdAY's Avatar
Default B20 Vtec timing belt?
Hey guys, I'm in the process of building a CR-Vtec. I'm running a stock B20B bottom end with a stock B16 head and water pump. My question is, which timing belt are you likely to run and how many teeth?
Old Aug 17, 2011 | 12:08 PM
grumblemarc's Avatar
The Grumpiest
Default Re: B20 Vtec timing belt?
Are you following a guide/DIY of some sort? I was always under the assumption that you use the belt for the head. Your guide/DIY should tell you.
Old Aug 17, 2011 | 12:22 PM
kyden's Avatar
belt matches water pump. you would use a gsr/itr timing belt if you're using a vtec water pump.
Old Aug 17, 2011 | 04:12 PM
civickiller's Avatar
+1
ls waterpump/ ls belt
gsr waterpump/ gsr belt
when i first did my lsv, same as b20v, i used a ls wp/ ls belt. later went turbo so i switched to gsr wp/gsr belt
rick_rabies
Apr 1, 2009 12:59 PM
B18 CYA
May 11, 2005 03:11 PM
whiterex
Jan 27, 2005 11:58 AM
Norcalstoppy
Aug 7, 2003 01:13 PM
Boost2NA
Oct 31, 2002 03:36 PM
