Broken sensors under distributor (with pics) please help me identify them
Old Aug 17, 2011 | 07:49 AM
timaccord95's Avatar
Default Broken sensors under distributor (with pics) please help me identify them
During the course of replacing the clutch in my 95 accord, two sensors right under the distributor managed to get broken. I think one of them is the coolant temp sensor, but I'm not sure. It would be much appreciated if anyone can tell me what these sensors are called so i can replace them.[IMG][IMG][IMG][/IMG][/IMG][/IMG]
Old Aug 17, 2011 | 08:03 AM
Rowdy Rod's Avatar
Default Re: Broken sensors under distributor (with pics) please help me identify them
That is the coolant temperature switch you have broken there. Without it, your radiator fan will most likely not come on. You can jumper it temporarily to drive the car to the auto parts store.
Old Aug 17, 2011 | 08:14 AM
GhostAccord's Avatar
The 2 wire one is the ECT sensor for the ECU and the single wire one is the temp sending unit for the dash. They are not the A or B fan switches. You will have a hard time running your engine without the ECT sensor and your dash temp gauge will not work without the other.
Old Aug 17, 2011 | 08:33 AM
Rowdy Rod's Avatar
My engine ran fine without the ect switch wire attached and I had it jumpered out. The only thing was the check engine light came on and had to be reset.
Old Aug 17, 2011 | 09:27 AM
Ran fine, may have felt that way but it probably wasn't 100%. When a CEL pops up it usually means that it wasn't running 100% and requires attention!
If you jumper the ECT wires that = 0ohms of resistance. The ECT is a temperature dependent resistor (thermistor). The resistance of this thermistor decreases at the engine coolant increases.
Therefore if you jump the ECT wires you are basically telling the ECU that the engine is running hot all the time. As 0.1 resistance = approx. 250°F. Or if there is 0 resistance, there is a problem with the ECT sensor. That will effect your timing and fuel maps or put you in failsafe/back-up mode, this is a pre-programmed value for the particular erroneous sensor.
It will throw a CEL, run in fail safe/back-up mode and inform you to replace the ECT sensor. Ether way you may think your engine is running fine, however the computer is adding/removing fuel and adjusting timing for a hot engine when it's not.
Just thought you might want to know what it was that you did when you jumped the wires.
Old Aug 17, 2011 | 11:10 AM
Rowdy Rod's Avatar
You are right of course. I only drove my car a short time without the ECT wires hooked up. Was for testing. Thanks for the clarification.
Old Aug 17, 2011 | 11:11 AM
Thanks everyone so much for the help! So these two sensors being broken would be the cause of my car not being able to start? And can someone explain what it means to jump the wires?
Old Aug 17, 2011 | 11:32 AM
To jump the wires means to close the circuit, aka join them together.
Not so sure that the ECT would cause your car not to start. You might want to re-check all of your ground and power connections.
Old Aug 17, 2011 | 04:08 PM
Word I'l do that. Thanks again for the help. My accord has been off the road for way too long lol I miss driving it.
mon2mon2
Jan 17, 2022 06:49 PM
BDaTurboTeg
Oct 26, 2013 12:55 PM
arkomandos
Nov 15, 2010 09:15 PM
cehcivic15
15
Feb 22, 2010 12:31 PM
dickeytk
Oct 27, 2006 12:00 PM
