Step by step guide -> removing CX engine -> dropping in B16A -> ????
Anyone have a good link to a step by step comprehensive guide through the entire removal process for the old CX engine and putting my new JDM b16 in?
I know how/what to do for most of it.. I just dont want to get stuck somewhere along the way with some stupid problem.. or forget to do something.. etc...
Anyone?
(btw i searched, do u have any idea how many people casually say "engine swap" or "b16 swap" in their posts?
Anyone?
B18c1 into 5th gen
B18C1... practically the same process. Alot harder than they make it out to be. They may casually say..."Remove this tranny bolt".
They don't tell you that you have to rip off the heat shield (with stripped bolts, of course
) and exhaust mani just to get to the damned bolt. Good luck!
PS, thats the JDM motor, so wiring will bne different too. I'm about to do the same swap. In the hybrid forum, some people tell me to use the stock Si harness and run new wires, while others say they had no problems using their JDM harness. I don't think you're prewired for VTEC tho
, so once again, good luck !
[Modified by fOmaNPu, 3:15 PM 10/3/2002]
you can just do whats comes as common sense to you as far as taking it out and putting the b16 in and when and if you have any problems just ask us im sure we will all be more than hapy to help
good luck
good luck
cx's are pre wired for vtec
[Modified by ill phil, 9:32 PM 10/3/2002]
Radyjr
Aug 18, 2005 06:56 PM
[PLEH]EG6
Jul 23, 2003 06:13 AM
