Step by step guide -> removing CX engine -> dropping in B16A -> ????
Old 10-03-2002, 11:50 AM
Prevail's Avatar
Default Step by step guide -> removing CX engine -> dropping in B16A -> ????
Anyone have a good link to a step by step comprehensive guide through the entire removal process for the old CX engine and putting my new JDM b16 in?
I know how/what to do for most of it.. I just dont want to get stuck somewhere along the way with some stupid problem.. or forget to do something.. etc...
Anyone?
(btw i searched, do u have any idea how many people casually say "engine swap" or "b16 swap" in their posts? )
Old 10-03-2002, 12:01 PM
hydroflip's Avatar
Default Re: Step by step guide -> removing CX engine -> dropping in B16A -> ???? (ride_with_me)
get a helms
Old 10-03-2002, 12:13 PM
fOmaNPu's Avatar
B18c1 into 5th gen
B18C1... practically the same process. Alot harder than they make it out to be. They may casually say..."Remove this tranny bolt".
They don't tell you that you have to rip off the heat shield (with stripped bolts, of course ) and exhaust mani just to get to the damned bolt. Good luck!
PS, thats the JDM motor, so wiring will bne different too. I'm about to do the same swap. In the hybrid forum, some people tell me to use the stock Si harness and run new wires, while others say they had no problems using their JDM harness. I don't think you're prewired for VTEC tho , so once again, good luck !
[Modified by fOmaNPu, 3:15 PM 10/3/2002]
Old 10-03-2002, 12:23 PM
-Whitey-'s Avatar
Default Re: Step by step guide -> removing CX engine -> dropping in B16A -> ???? (fOmaNPu)
you can just do whats comes as common sense to you as far as taking it out and putting the b16 in and when and if you have any problems just ask us im sure we will all be more than hapy to help good luck
Old 10-03-2002, 12:28 PM
oldB18EF's Avatar
Default Re: Step by step guide -> removing CX engine -> dropping in B16A -> ???? (One Honda)
cx's are pre wired for vtec
Old 10-03-2002, 12:30 PM
ill phil's Avatar
Default Re: Step by step guide -> removing CX engine -> dropping in B16A -> ???? (WR93EG)
I thought that was only for 92.....actually I'm pretty sure it was only 92's
[Modified by ill phil, 9:32 PM 10/3/2002]
Old 10-03-2002, 03:54 PM
fOmaNPu's Avatar
Default Re: Step by step guide -> removing CX engine -> dropping in B16A -> ???? (ill phil)
Old 10-03-2002, 04:06 PM
Turbo Powa's Avatar
Old 10-03-2002, 05:35 PM
BoostedGSRBubble's Avatar
Default Re: Step by step guide -> removing CX engine -> dropping in B16A -> ???? (Civic LX 29)
Step 1. SEARCH
Step 2. SEARCH some more
Step 3. RESEARCH
pos_cd5
08-22-2006 01:07 AM
Radyjr
08-18-2005 06:56 PM
eg6T
02-12-2005 06:40 PM
hookeduphatch95
09-15-2003 05:07 PM
[PLEH]EG6
07-23-2003 06:13 AM
Quick Reply: Step by step guide -> removing CX engine -> dropping in B16A -> ????
