Misfire after head and valve job
Old Aug 16, 2011 | 03:16 PM
SeanK325's Avatar
Default Misfire after head and valve job
98 civic with a d16y8. Misfire in #3. CEL is blinking and code P0303. This never occured before the valve and head job which were for a blown head gasket. Any ideas..? I have spark, but not sure if i have fuel or air.
Also, new valve seals and valve adjustment.
Old Aug 16, 2011 | 03:20 PM
SeanK325's Avatar
Default Re: Misfire after head and valve job
Got new plugs and wires. Cap and rotor seem fine, but i don't want to buy a new set if it's something else. Like I said, I have spark.
Old Aug 16, 2011 | 03:58 PM
motegicivic's Avatar
Did you install the cap rotor and wires?
could be as simple as a bad wire.
Old Aug 16, 2011 | 04:00 PM
SeanK325's Avatar
new plugs are installed. i thought it was a wire because the #3 plug felt like it wasn't "clicking" in, but still have the same problem with the new wires. I haven't changed the cap, nor the rotor. I'm wondering why it would misfire after this and never once before. I didn't want to just buy new parts. I'm trying for a budget. I'm just a student. Could it be a bad O2 sensor or a bent valve?
Old Aug 16, 2011 | 04:01 PM
SeanK325's Avatar
and I triple checked my firing order on the dizzy and the engine. everything is right.
Old Aug 16, 2011 | 04:12 PM
honda fossil's Avatar
did you dubble check the valve clearance... if the valve is too tight it will missfire and if it is real loose it is a sign that the valve may be bent ..
Old Aug 16, 2011 | 04:15 PM
SeanK325's Avatar
Isn't that something for the guy who did the valve to check?
Old Aug 16, 2011 | 04:17 PM
every body f' s up know and then he could have the # 3 valves to tight
Old Aug 16, 2011 | 04:21 PM
SeanK325's Avatar
Damn I don't want to pull the head again but it seems like that's what I'm gonna end up doing.
Old Aug 16, 2011 | 04:25 PM
don't pull the head just remove the valve cover and check the clearance
Old Aug 16, 2011 | 04:43 PM
SeanK325's Avatar
Ok I'll have my cousin do it tonight.
Old Aug 16, 2011 | 06:15 PM
SeanK325's Avatar
We got it! Valve was too tight. Runs great now. thanks for the help.
Old Aug 18, 2011 | 05:11 PM
cool glad to be of help
Old Aug 18, 2011 | 08:36 PM
SeanK325's Avatar
that's why i love this site.
Old Aug 18, 2011 | 08:47 PM
hondazzle's Avatar
feeler gauge and a chilton manual, do your own maintenance and the questions will steadily disappear.
Old Aug 18, 2011 | 08:59 PM
strategy400's Avatar
For some reason it seems like the shops always leave a few too tight. And they surely don't "adjust" them with any type of accuracy (unless maybe they're shimmed).
Old Aug 18, 2011 | 09:17 PM
SeanK325's Avatar
My cousin is much more mechanically inclined than I am, especially on Hondas. Glad to have him in my corner. I usually try and do things myself, but I felt this was over my head.
greenskittle
23
Jul 26, 2012 01:39 AM
rgg1970
Sep 6, 2010 01:58 PM
drock305
Oct 7, 2008 06:05 PM
dynamitezz
Oct 28, 2006 08:07 PM
