Suspension & Brakes Theory, alignment, spring rates....
Going through front upper control arms like water.
Old Aug 16, 2011 | 08:08 AM
skylinerb26dett's Avatar
Default Going through front upper control arms like water.
Hello everyone. I have a question. My car is a 96 Ek hatch. Lowered on function and form type 1 coilovers. Lately I have been going through upper control arms like crazy. I do get ones from napa but about a week after I put them on they start making noise again. Like a popping. So I was wondering if something else is wrong or it's time for aftermarket ones? I was gonna get ksport adjustable ones. Any advise or tips would be great! Thanks
Old Aug 16, 2011 | 08:13 AM
kyden's Avatar
Default Re: Going through front upper control arms like water.
sounds like you need to buy real oem ones.
1991civiclx13's Avatar
camber kit, or raise your car sum
Old Aug 16, 2011 | 08:40 AM
If I was gonna spend that much for oem, shouldnt I just get aftermarket?
Old Aug 16, 2011 | 03:31 PM
GagnarTheUnruly's Avatar
Only if aftermarket are better. In this case, they're not, because OEM ball joints are the best available.
What is making noise -- the ball joint or the bushings? If it's the bushings, you might not be installing them correctly. If it's the ball joints than it's a build quality problem.
PS I'm assuming you're talking about the front UCAs nm says so in title
Old Aug 16, 2011 | 03:59 PM
98civdx's Avatar
Master Detailer
Get OEM arms from the dealer.
Old Aug 17, 2011 | 05:53 PM
alright guys. ill just get OEM ones thanks for your help!
Old Aug 18, 2011 | 06:15 AM
phunhaus's Avatar
Raise your car. It's more than likely the bad angle of the ball joint as the root of the problem.
Old Aug 18, 2011 | 06:58 AM
Andy@AMR's Avatar
How low are you? Any cracks on your shock tower?
Old Aug 24, 2011 | 09:24 AM
I'm not crazy low, Not all the way down or anything. But tucking tire for sure. Where on the shock tower?
Old Aug 24, 2011 | 09:41 AM
There she is. I don't think I'm like crazy low.
Old Aug 24, 2011 | 10:25 AM
TunerN00b's Avatar
No, that's fairly slammed.
Right next to the upper shock mount, where the UCA would hit the shock tower, is where you should look for cracks.
Old Aug 24, 2011 | 10:32 AM
Ohh I see what you mean. There really isnt any cracks
Old Aug 24, 2011 | 10:33 AM
^^ like where people cut holes so the uca doesn't hit?
Old Aug 24, 2011 | 12:55 PM
phunhaus's Avatar
Then check for your axles clicking.
If you need your car to be that low, expect these kinds of problems to constantly need your attention.
Old Aug 29, 2011 | 08:43 PM
stock95coupe's Avatar
Hold your hand with your fingers straight out. Then with your other hand, bend them upwards and don't stop when it starts to hurt... Yeah, that's what you're doing to your UCA ball joints on hard bumps.
If you put your car on a jack, can you see *any* signs far up in the wheel well that any part of the UCA is hitting the frame? Sometimes the fender liner at the very top towards the inside has too much left on it, specifically inwards of the frame's seam. The UCA's outter lip will catch, and will result in unusual noises.
Old Sep 6, 2011 | 09:33 AM
bennyBronco's Avatar
check your suspension housing. there might be some rubbing on your conrol arm... ive seen control arms trying to poke out on flushed cars.
Old Sep 6, 2011 | 09:47 AM
Andy@AMR's Avatar
Any updates on this, how are things now? Find anything??
dazebreak
Sep 2, 2016 06:17 PM
freshane
Suspension & Brakes
16
Sep 24, 2012 10:33 AM
offcamber
49
Apr 10, 2010 09:05 AM
PatrickGSR94
Suspension & Brakes
14
Dec 4, 2008 06:08 AM
Teal5GenHatch
11
Jul 27, 2006 06:21 PM
