B16 engine build help
Old Aug 15, 2011 | 11:51 PM
BlazeB16a2's Avatar
Icon2 B16 engine build help
Oks I have a 99 si with the b16a2 and im looking in a complete NA build so plz no "U should turbo it" advice..
Ill be basically piecing together my own stroker hit and my main question so far is should i leave my stock cylinder walls at 81mm and have the stroker displace it to a 1.75 liter or bore it to 84mm and have it displaced to a 1.9 liter engine? And if i go with the 1.9 liter what would that do tu my redline? keeping in mind ill have the whole valvetrain done up... And the end result the engines compression would be brought up to 11:1
Cookbook so far.. looking for suggetsions and comments
b16 bored to 81mm or 84mm depending..
CP high comp pistons
Eagle connecting rods
B18 or LS crankshaft
SKunk2 pro series stage 2 camshafts
SKunk2 Springs/Retainers & valves
P72 virgin Ecu
Hondata S200
I just keep thinking im missing things since im new to the game and still learning
Old Aug 16, 2011 | 12:24 AM
rhymeshark916's Avatar
Default Re: B16 engine build help
Why not b18 or b20 blocks?
Old Aug 16, 2011 | 02:10 AM
BlazeB16a2's Avatar
Y swap the block and risk mis matched vins when i can stoker my block since id have to change the swapped b20 blocks internals to up the compression anyway
Old Aug 16, 2011 | 06:17 AM
grumblemarc's Avatar
The Grumpiest
Post this in the N/A forum if you want relevant answers OTHERWISE be prepared to get all sorts of opinions.
Old Aug 16, 2011 | 07:07 AM
Red_Army's Avatar
wow...change your list before stepping in the NA forum.
risk mismatched vins? running stolen **** are we?
more research. kinda missing a pandp, intake, IM, header, exhaust, and tune.
get a b18 or b20 block.
i want you to explain how your ramming those cranks into a 1.6.
if you do bore it to 84 you'll need sleeves.
get s300 if any hondata. also neptune chrome ectune are all better and cheaper programs.
Old Aug 16, 2011 | 09:57 PM
BlazeB16a2's Avatar
Still learning how to use this site repost on the NA forum??
No not stolen lol just saying if i swap the blocks and a cop that knows what hes looking at sees a diff head and block i dont want to get reffd
And i already have col air and headers with 2 1/2 in collection necked down to 2 in piping after the high flow cat
and from what little i understand the ls crank from the b18 can help chnge the stroke will fit right in the b16 block thus being part of the stroker kit
and ii havent found any info on how much the boring and sleeving would cost to get at a shop... i live in the IE in southern cali
Old Aug 17, 2011 | 08:20 AM
Red_Army's Avatar
it'll take some custom pistons thats all. theres a subforum called all motor.
oh well then you can't have a b20 anyways. so exnay that idea.
you'd have to get it reffed anyways wouldn't you? im sure they've had engines that have been broken and replaced over being rebuilt.
BlazeB16a2
20
Sep 6, 2011 05:21 PM
that honda kid
23
Mar 22, 2010 07:17 AM
Milab21
21
Aug 31, 2008 06:14 AM
wickedEFguy
Jan 29, 2004 11:22 AM
Mr Hammond
Mar 2, 2003 12:48 PM
