B16 bottom end...and revhard stage 2 ?'s
well I'm swapping in a B16 in my CRX and going with a stage2 revhard kit and I'm wondering how much boost my bottom end is going to be able to handle..
I am lowering compression to 9.1:1, eagle rods & pistons, RS sleeves, ACL bearings and retainers, Skunk2 turbo cams and the head will be ported and polished..There's a few other things but you get the idea
with this kit I know that the External wastegate spring is set to 8 but I plan on uping the boost around 15+ when I get my hondata and larger injectors.
should I have the bottom end rebalanced or should I be ok?
12 Years Strong
Re: B16 bottom end...and revhard stage 2 ?'s (wicked B16)
If you have the fuel 12 would be as high as I would go on a stock block, but thats just me
666 posts yo!
666 posts yo!
U should be good for any amount of power you throw at it, considering your u got a good tune on the engine. If your looking for a figure its probably good for over 500.
As far as the balancing goes just balance the crank.
