99 EX with 97 Y8 Motor, Super High Idle, Code 14, Troubleshooted for 4 days! Help LOL
Old Aug 15, 2011 | 08:38 PM
IMPORTMyth01's Avatar
Default 99 EX with 97 Y8 Motor, Super High Idle, Code 14, Troubleshooted for 4 days! Help LOL
I have troubleshot everything I could think of and have only come to the conclusion that the setup/combo that I am stuck with just needs a jumper harness and a chipped ecu. I am trying to avoid the $250 cost of that since the car is nearly all stock.
Here is what I have:
1999 Civic EX with OBD2B wiring, dizzy, etc. 2 Wire Manual IACV
1997 D16y8 Engine with a 1999 Intake manifold (motor blew and previous owner replaced with a 97 version)
Wiring is all checked out tested at ECU and plugs.
Tried 3 different IACVs, tried blocking it completely,
Plugged every port and yet still the idle cranks at 3k RPM and surges after warm up from about 1500-2500...never had one this high before.
Only thing I am thinking of is the air ports on the intake manifold, however since the 97 heads dont have the small holes for air injection then technically just plugging the big port on top would just seal it off no problem.it should actually idle really low.
Idle screw turned in all the way.
Timing I am sure is a little off but with an idle that high I cant fine tune it.
At highway speeds car runs like a champ...low speeds it bogs, bucks, and breaks up.
Maybe using the P2P ECU is throwing the code since its actually looking for the air injection thats not there?
TIA
Old Aug 15, 2011 | 09:02 PM
Former User's Avatar
Default Re: 99 EX with 97 Y8 Motor, Super High Idle, Code 14, Troubleshooted for 4 days! Help
I'm almost certain that the 99 IM with the fuel injection air intake system is your problem.
Old Aug 16, 2011 | 03:42 AM
Ok. Going to plug the holes tonight and see what happens from there.
Old Aug 16, 2011 | 08:02 AM
motegicivic's Avatar
Didn't the 99-00 have a cold start valve something.....that the 96-98 did not have?
Old Aug 16, 2011 | 08:06 AM
Did you read the thread?
Old Aug 16, 2011 | 08:09 AM
I did, but I was asking when he said "dont have the small holes for air injection" was that the cold start valve, were the holes for that?
Why was this valve added.........
I can say I have hard cold starts on my 96 ex.....was this the reason was added.
Old Aug 16, 2011 | 08:17 AM
This is the answer to your questions:
Only 99-00 Civic D16Y8 engines have this air intake system.
Old Aug 17, 2011 | 08:15 PM
Plugged the holes and good to go!
Since the 99-00 Engine set contains the fast idle valve in the thermo housing I guess I could have opted to install a 96-98 throttle body however it idles perfect and runs like a dream so good to go.
Thanks RonJ@HT for reassuring I wasnt plugging the holes and scraping off another gasket for no reason!
OrangeChrome
47
Oct 14, 2013 05:34 AM
97ekcoupe
Mar 18, 2007 09:32 AM
hondaguyef
Sep 28, 2005 04:30 PM
ransack
May 25, 2003 04:11 PM
