Need help - 2000 civic bad spark
Old Aug 15, 2011 | 05:20 PM
Phoenix27101's Avatar
Icon3 Need help - 2000 civic bad spark
I have a 2000 Honda Civic 143,000 miles, that I have owned for 2 days. When I bought the car, it ran perfect. No check engine lights, nothing. After a solid day of riding around in it to get tags and the such, the check engine light came on. I plugged it in to my code reader, and it ran bad Cat, but otherwise, it ran great. The previous owner told me the car had been sitting for a few months.
The next day I was driving the car, and out of teh blue, it shut down to what appeared to me as two cylinders. After about 30 seconds, the car ran great again.
The day after that (3rd day), I jump in the car, and it runs only on 1 or 2 cylinders again. I start it up mid day, when a little warmer, and it runs great again (100 degrees F). Shortly after, it will not start at all.
Things I have done to fix this: I have fuel, checked the gas at the rail; I have air. However, my spark is odd. In the middle of the hot day, spark is almost regular, but as it cools down spark is non existent. I have replaced the distributor, a visual inspection of the wires to the distributor seem OK. I visually inspected the fuses, they seem OK as well. I have also replaced the O2 censer, thinking taht was what may have caused it to read for the cat. Since I unplugged the battery no codes show on the ECU, even when I know one of the O2 censors were disconnected.
I'm at a loss. Help is appreciated. One more thing to note, when the car was running, but was running poorly on day 2, the cat didn't seem plugged.
Thanks.
Old Aug 15, 2011 | 08:37 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Need help - 2000 civic bad spark
sounds like the guy you bought it from had a band-aid on it to unload it..
im means there can be so many things..
did u try replacing plugs and wires?
If the car has been sitting for months, it might be bad gas..
just stabbing in the dark here
Old Aug 15, 2011 | 09:07 PM
98civdx's Avatar
Master Detailer
Did you replace the plugs? It's not much for a set of NGK plugs, repalce them.
You say the wires look good? but do you know how old they are? It's quite likely they are the OEM plug wires.
Old Aug 15, 2011 | 09:39 PM
I have replaced the plugs and wires. No go.
Old Aug 15, 2011 | 09:48 PM
Retired Moderator
hmm, no spark... ECU?
know any other Si's that you can swap real quik to check?
hmm cap and rotor- check
plugs and wires - check
grounds?
firing order after dist change?
injectors?
im still stabbing here
Old Aug 16, 2011 | 10:20 PM
I pretty sure the firing order is correct. All the engine grounds seem in good shape.
Old Aug 17, 2011 | 07:10 AM
motegicivic's Avatar
Check the coil?
Old Aug 17, 2011 | 09:10 AM
casper_hb's Avatar
IACV???
revoapparel
11
Sep 17, 2011 10:23 AM
20sir00
65
Apr 7, 2010 03:25 PM
Azxster
11
Feb 25, 2008 10:06 AM
quad
20
Mar 14, 2007 05:16 AM
